Author Topic: Cant resync key.  (Read 60837 times)
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Cant resync key.
« on: 25 May 2024, 19:13:30 »
Second key for the Omega. Is rarely used. Last time probably two or three years ago.
Put a new battery in it today. Put key in ignition, turned to position one (also tried with ignition on) pressed lock unlock several times, nothing doing.
Could be battery connections inside key, but as it doesnt get used its hard to see how its got damaged.
Any other possibilities I can check ?
  • Online Online
Re: Cant resync key.
« Reply #1 on: 25 May 2024, 20:43:28 »
Is it a 'just purchased new' or 'sat in a drawer unused for two years' new? :-\
Migv6 le Frog Fan
« Reply #2 on: 26 May 2024, 00:56:30 »
Came with the car seven years ago and has been on swmbos keyring, largely unused since then.
Tested voltage in the new battery and it showed just over 3v.
« Reply #3 on: 27 May 2024, 17:54:21 »
Pop apart and check if batt connections are broken (where metal bit attaches to PCB).
Photo if not sure.
Migv6 le Frog Fan
« Reply #4 on: 27 May 2024, 21:04:24 »
Will do. Thanks.  :y
    • E250 Est / Elroq
« Reply #5 on: 28 May 2024, 06:50:54 »
Ive a vague memory the fob resync only works with the door open, or closed...not either, and cant remeber which one...but only 2 options to try....
« Reply #6 on: 28 May 2024, 09:49:11 »
I only ever tried with it closed, so never noticed ;D
    • Grandland 1.5 diesel
« Reply #7 on: 28 May 2024, 15:31:01 »
You've never lived till you've tried it with the door open.
Diesel till I die
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #8 on: 28 May 2024, 17:01:03 »
;D
Or stood outside the car , reaching though the window  :P
Migv6 le Frog Fan
« Reply #9 on: 28 May 2024, 17:48:27 »
I think thats called Dogging.  :D
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #10 on: 28 May 2024, 18:56:01 »
Nah !
All the people in the local park rarely have pets with them  ;)
they all seem very loving and affectionate  :)
though I don't know WHY they don't change the batteries in their car keys while it's light  :-\
always seems to be late at night  ???
« Last Edit: 28 May 2024, 19:00:06 by dave the builder »
  • Online Online
« Reply #11 on: 28 May 2024, 19:14:31 »
Daytime is certainly much better, more people to potentially catch you jiggling your fobs... >:D
Migv6 le Frog Fan
« Reply #12 on: 28 May 2024, 19:55:29 »
Anyway....................Im back in work friday night where I can insoect it under an illuminated magnifier, so shall take a look at it then.
« Reply #13 on: 29 May 2024, 09:05:58 »
Is that like throwing them in a bowl with other people's keys?
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #14 on: 29 May 2024, 12:17:57 »
That's how it broke in the first place.  ::) :)
