Author Topic: Central locking won't lock  (Read 42772 times)
Jim82
  • High Wycombe
    • Omega 2.6 Elite Estate
« on: 04 July 2024, 13:46:31 »
Left the omega parked up for a week or so. Returned to it today and unlocked it to get something out of the boot.
Closed the boot, pressed lock and the car locked and then unlocked itself again. I haven't disturbed any other doors than the tailgate. Any ideas? Every time I try and lock it I'm getting the same response.
*Update* I got in and tried to start it in case it was a low voltage issue and the battery is indeed low enough to fail to turn the starter. Could this be having an effect?
Re: Central locking won't lock
« Reply #1 on: 04 July 2024, 13:56:00 »
It's a good place to start ;)
Bouncing locks is otherwise an indication of failing drivers door solenoid.
Jim82
  • High Wycombe
« Reply #2 on: 04 July 2024, 14:21:01 »
Didn't have time to mess about with it before leaving for work so I've just had to manually lock all the doors and boot. Haven't had to do that particular operation since the early 90s  ;D
« Reply #3 on: 04 July 2024, 14:51:21 »
Manual locking and then unlocking with the remote won't trigger the alarm, so that's a plus :y
« Reply #4 on: 04 July 2024, 15:09:16 »
Did on all mine. Not sure if plod were different?
« Reply #5 on: 04 July 2024, 22:02:43 »
Locking with the remote and unlocking manually ALWAYS set it off.
The only difference between plod and not IMHE was no power sounder or rear quarter glass breakage sensors.
« Reply #6 on: 05 July 2024, 17:59:49 »
Mine used to go off if locked with key and unlocked with key as well.
Jim82
  • High Wycombe
« Reply #7 on: 09 July 2024, 20:13:24 »
Update: Battery kept going flat - eventually traced to passenger side sunvisor mirror lamp!
Central locking working absolutely fine once battery charged, and visor bulbs removed as a short term fix.
« Reply #8 on: 09 July 2024, 21:23:06 »
Good find :y
That has to be one of the more obscure drains...
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #9 on: 17 July 2024, 17:14:29 »
How did you find it ?
    • Grandland 1.5 diesel
« Reply #10 on: 17 July 2024, 20:33:49 »
He just put the visor down and there is was  :)
Diesel till I die
Jim82
  • High Wycombe
« Reply #11 on: 18 July 2024, 11:04:12 »
Pretty much this  ;D
Can't take the credit really, as all I did was Google "vauxhall omega battery drain" and the first result that came up was "check your sun visor lights aren't staying on"
« Reply #12 on: 18 July 2024, 11:26:59 »
Are your survivors sagging?
If so it might be an idea to put a strip of tape across the contact in the clip. Doesn't have to cover the whole contact, just the first half.of the range of movement so that it has to definitely be down before the lights come on.
    • 530D M Sport, 330i Coupe
« Reply #13 on: 18 July 2024, 13:04:00 »
Absolute classic!  ;D
Migv6 le Frog Fan
« Reply #14 on: 18 July 2024, 13:47:51 »
Dont encourage him.  ::) ;D
