Author Topic: Automatic transmission not stsrting engine at N  (Read 25289 times)
jimjimanta
  • hellas
    • opel omega b , opel manta
« on: 01 September 2024, 14:40:06 »
I have a problem with the starter engine,
when transmission is in position N .
the engine does not start,
if I don't push him towards position D.
where is the start button and how is it set up ?
Re: Automatic transmission not stsrting engine at N
« Reply #1 on: 04 September 2024, 10:47:21 »
Pretty certain the start inhibitor circuit goes through the "range switch", also known as the selector switch, which is bolted on the side of the gearbox by 2 screws.  Do the LED's by the side of the gear level light up correctly, ie, does that panel show the car is in N?
grifter
  • Paisley, Scotland
    • Omega 2.6 CD / Elite 3.2
« Reply #2 on: 11 September 2024, 21:19:11 »
Mine sometimes does this in 'N' have to wiggle the lever a slight way back and forward occasionally for it to crank.
jimjimanta
  • hellas
« Reply #3 on: 25 April 2025, 08:19:51 »
Yes , light N , but not starting
Dave_G
  • Nottingham
    • 2002 2.6 Elite Estate
« Reply #4 on: 27 April 2025, 12:38:00 »
I get this every now and then. A bit scary at first when you don’t know what it is and you just get a ’clunk’, when turning the key, but as just said, moving the selector back and forth sorted it.
If my current problems get resolved I might do the selector clean as described on the forum.
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #5 on: 27 April 2025, 18:24:24 »
Was going to be my suggestion, I've never owned an auto Omega but I've seen the guide referenced before.
« Reply #6 on: 27 April 2025, 19:15:58 »
, I've never owned an auto Omega but  ....
I didn't know there was anything other than ....  ::)
