Author Topic: Possible immobiliser fault?  (Read 133713 times)
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« on: 10 September 2024, 08:54:26 »
Is there any way to completely disconnect the immobiliser on the Elite.....got a strange feeling that it's draining the battery down, power sounder was removed a few years back.....BTW electrickery is not high on my skill set. ::)
Re: Possible immobiliser fault?
« Reply #1 on: 10 September 2024, 10:13:03 »
There shouldn't be a drain on the immobiliser circuit, it's basically a loop from the engine ECU to the transponder ring iirc.
Disabling it isn't quite as straightforward as simply unplugging it though.
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #2 on: 10 September 2024, 14:08:46 »
 Ahh! you mean hitting it with the biggest hammer in the box ;) but did the next thing....fitted a battery isolator, that'll do for the winter as the cars don't get used much. Thanks for the explanation Al :y
« Reply #3 on: 10 September 2024, 15:30:50 »
Disconnecting is certainly the most effective way of stopping battery drains. ;)
Just be sure that the key operates the drivers door lock before you turn the power off and be sure to use the lock periodically to stop it seizing up :y
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #4 on: 12 September 2024, 06:29:20 »
Thanks, I've fitted battery isolators to all three now, just because of the lack of use and the coming winter weather. Also all  the batteries  are now fitted with  C-Tek connectors which makes keeping them charged that much easier.
« Reply #5 on: 12 September 2024, 12:42:30 »
Post 1995 models have an integrated immobiliser that can't easily be removed - it needs programming out of the ECU.
Why do you think its the immobiliser, and not, say, the consumer relay (reasonably common fault on Omegas)
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #6 on: 13 September 2024, 07:34:31 »
 Worth investigation, I guess there must be access to the relay.....but as I say electrickery is not a strong point, so didn't fancy chasing my tail. I'm guessing the relay location is in the under bonnet fuse box?
« Reply #7 on: 13 September 2024, 08:12:56 »
Under the dash iirc, but buried in the loom on an A pillar rather than under the steering column...
I want to say passenger side :-\
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #8 on: 13 September 2024, 08:31:10 »
Would that be behind the kick panel? as I took a look at the diagrams for it in the obvious places, and no luck ::)
« Reply #9 on: 13 September 2024, 09:04:33 »
Think it's further up than that :-\
There's not a guide for it surprisingly, but I think Kevin's Charging guide includes how to test for consumer relay function...
« Last Edit: 13 September 2024, 09:08:13 by Doctor Gollum »
Page created in 0.032 seconds with 20 queries.
