clocks change
Started by Faisca_40, 10 December 2024, 08:45:25
Faisca_40
hello all
i have an omega 2,5td from 1998(mini facelift) and my rev counter and temp gauge arent working great. my friend has a complete one with the color display(mine has the MID one) from a 2.5DTi from 2001. it´s possible to apply the clocks and the color display in my car?
tank you all
speedy_ns
No. You need double DIN head unit paired with that color screen+ wiring harness. Color screen is controlled via head unit, not through wiper stalk. Other option is to find HU from Astra/Vectra with color screen but there's still mater of wiring..
Speedo cluster is separate part and I believe they are interchangeable as long as transmission is the same, but I'm not sure. M57 ( DTI ) has ''drive by wire'' instead of cable, so there might bee differences.
Faisca_40
Quote from: speedy_ns on 10 December 2024, 09:12:04
ahh ok. the transmission is the same(manual) mine is drive by wire also, no cables. guess i'll stick with the MID display.  ;D
Faisca_40
if i had an Siemens NCDR 1100, the color display will work?? just asking...
Depends on what car it came from and if it has been correctly delivered paired.
Unless you're fitting the NCDR1100 with it although if it's not from an Omega, it probably won't work.
Faisca_40
Quote from: Doctor Gollum on 10 December 2024, 12:15:36
ok, thank you for the reply's, i'll stick with the MID.  :D
