Typical...
Started by Migalot, 31 December 2024, 20:24:10
Migalot
Vaillant boiler decides to stop working on New Year's Eve. Regularly serviced (last time 07 June 2024).
No display, but pump sounds.
No chance of an engineer until at least Thursday.
Not a happy bunny.... :(
LC0112G
There is a way to get trouble codes on my Vailiant boiler. Involves pressing front panel buttons. Google your boiler model number and something may appear.
Migalot
Quote from: LC0112G on 31 December 2024, 20:32:01
It's a Vaillant Ecotec Plus 837. Display should be automatically showing, I think.
LC0112G
Quote from: Migalot on 31 December 2024, 21:12:34
In which case, it should show an 'F' code, which you can decyper on t'interweb.
Then once you know what it's whinging about, there should be an engineering screen that you can enter by pressing various combinations of buttons. Once in the engineering screen you can scroll through various parameters to see if they make sense.
Migalot
Quote from: LC0112G on 31 December 2024, 21:20:50
Screen is completely blank. Not lit. Pressing buttons does nothing.
LC0112G
Not familiar with your boiler. On mine, (an Ecofit 412) the LCD display is permanently on, but to get the backlight to light you have to push any of the front panel buttons.
If the display isn't lighting up or showing anything then I'd be looking for an electrical fault in the mains supply to it. Either an isolating on-off switch somewhere (there should be one) or a fuse/circuit breaker.  But you say the pump is working, so perhaps not.
countrywoman
You left sodding of the title.
Quote from: countrywoman on 31 December 2024, 23:00:57
Not sure that will fix it...
Migalot
Vaillant engineer just called – PCB dead. Now replaced and all is good!  :y
House defrosting... ;D
YZ250
#9
Quote from: Migalot on 02 January 2025, 12:15:35
My sister has had 2 replacement PCB's in her Vaillant boiler (same symptoms as yours), both times covered under her home insurance policy. The first time it happened was after a power cut and the second time it happened was after a dodgy socket tripped the mains. Both engineers told her to always switch off the boiler on the boiler switch, not the isolation switch or the mains trip. He said that they are prone to spiking when the power goes off for whatever reason, so there could be some truth in that, although in her case she was powerless to prevent it.
I'd better add for safety reasons, that if anyone plans on working on the boiler, that the isolation switch or mains trip should be switched off once the boiler is off, just in case anybody misinterpreted what I meant.
Raeturbo
Could you install a surge protector?
Laying a rubber road.
YZ250
Quote from: Raeturbo on 02 January 2025, 13:01:36
Yes, I believe you can.  :y
My vaillant has been chugging along nicely for over ten years. Never had a service and been through plenty of power cuts. Has to work very hard to keep this leaky old place warm.
Diesel till I die
ronnyd
Hope you've got a carbon monoxide detector.  :) Though my old service engineer, who has since retired, reckoned that the domestic ones weren't worth a shit.
