Author Topic: Help decoding paperclip test: 97 pfl X20XEV Opel Omega simtec  (Read 4242 times)
pahaahv
  • Estonia
    • Opel Omega X20XEV 97 auto
Hello
I'd like to ask for some assistance in decoding my EML flashes from paperclip test. I followed the advice given here in this older topic:
https://www.omegaowners.com/forum/index.php?topic=90581.0
I recorded a video of the test:
https://www.youtube.com/watch?v=yc6ZcBpd5Kg
As stated in the video the car is 97 pfl X20XEV Opel, has a simtec 56 ECU manufactured in october of 96. That's all I know.
How can I exactly decode the flashes?
What I'm seeing is that it flashes only:
10
3
3
5
...over and over again and nothing else.
The car has been suffering from starting problems occasionally and last night I drove it for maybe 10km with the AC on HI and full blast and the temperature was rising to near 100C. When I noticed it I immediately shut off the AC. It fell down to 95-97C. Today it was about 95C. The coolant is near the "kalt" line if hot. Will check the level when it has cooled down. A significant problem?
I live in Estonia and right now there's a lot of snow and the temperature outside is -5C if that's important. The service i went to in october put in GM 5w-30 oil if that's important.
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
Re: Help decoding paperclip test: 97 pfl X20XEV Opel Omega simtec
« Reply #1 on: 04 January 2025, 11:14:01 »
its reporting P0335    incorrect rpm signal so to me that suggests a problem with the crank sensor or connection.
someone more knowlegable than ne on these early cars should be along soon to offer more advice if required
pahaahv
  • Estonia
« Reply #2 on: 04 January 2025, 11:30:50 »
Thanks man! An obvious problem looks like, but can you explain to me how do you get p0335 from 10,3,3,5? 10 = p0?
cam.in.head
  • West yorkshire
« Reply #3 on: 04 January 2025, 14:31:50 »
yes 10 flashes -zero
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #4 on: 04 January 2025, 14:34:28 »
The P in the fault code stands for Powertrain, which indicates that the issue is related to the engine, transmission, or drivetrain.
0 is represented by 10
So in your case P (powertrain) 10 =0, 3, 3, 5.  :y
This DTC (fault code) can then be either looked up on this forum or googled. Hope that helps.  :y
