MOT on the Mazda
Started by Terbs, 17 February 2025, 13:10:46
Terbs
Really pleased, took the Mazda in for MOT...passed. That's nine clear passes in a row without any advisories. Mind you, its only done 59000, and most of that is A34, M27 and A31, barely any local, so not much pressure on the joints, I suppose. :)
Can't get the Omega done , as its still in a static state :(
YZ250
Nice one on the Mazda.  :y  What's up with the Omega, I've forgotten.  :-[
Rangie
Quote from: Terbs on 17 February 2025, 13:10:46
Had a Mazda 626 diesel estate from new bought it in 2002 kept it 10 years & never failed an MOT . It was the most economical car that we'd ever owned up till now 46mpg running around & 60+ mpg on a run, got badly damaged rear end when SWMBO was using it so bought  an Omega as our daily.
Lizzie Zoom
Great result again then! :y :y
ronnyd
I had a Mazda 626, the first of the wrong wheel drive ones. it was very well screwed together but parts were hellishly expensive. I finished up running it with used parts. Nice car though.
Terbs
Quote from: YZ250 on 17 February 2025, 16:54:27
The Omega needs a new starter motor. Got in touch with James, he said he would do it, but heard nothing since ☹️ I'll have a crack at it, or my son in law may do it
it's my ML's MOT today .....
johnnydog
Quote from: Terbs on 17 February 2025, 22:44:01
It's not a difficult job - just fiddly. Access isn't good, but once the offside engine mount is released, the engine can be lifted on that side to greatly improve access to remove  / reinstall it from below.
Terbs
Yes mate, there is an excellent guide on here. My grandson took off the under panel and removed the lower starter bolt. Problem is, I can't get down under cars now...due to age, and as  someone once said, I look like a golf ball with legs !!!! ::)
Quote from: Terbs on 18 February 2025, 09:43:33....
the cheeky bugger!  ;D ;D
PM sent :y
Terbs
