TV problem?
Started by BazaJT, 01 March 2025, 15:53:57
BazaJT
I watch TV using Freeview.For the past few days if I select channel 17[Really]the picture is breaking up and the sound is stuttery.The same effect happens on channel 48[Challenge] and channel 60[U&Drama+1] although all the other channels from 1{BBC] to 82{Talking picturesTV] are fine including channel 20[U&Drama].I've tried retuning the TV but the problem remains,is anyone else having such issues? Any clues on the issue and how to fix it? The TV gets its signal from a roof top aerial as it always has and is not connected to the internet or any other source.
Lizzie Zoom
#1
Perhaps it is not relevant for where you live, but those channels via Freeview down here in Kent are fine. No problems.
But I have a booster on my aerial feed with good signal quality.
Has your aerial Baza been disturbed in any way?
All it needs is the aerial to be moved only slightly from its signal capture zone for the pictures on the weakest channels, as they are, to become distorted. ;)
Have a look at the signal strength on each of these channels vs the stronger ones, such as BBC or ITV, if you can via the info button. ;)
ronnyd
Moving on from Lizzie's post, some Freeview channels are not available in certain areas. If you get the Freeview guide up on your screen i think you could find out more. HTH.
Lizzie Zoom
#3
"..............and on from ronnyd post  ;D ;D ;D
Try going on this site to check what Freeview channels you should expect to get:
https://www.freeview.co.uk/freeview-channel-checker
If this is no different than before, back to checking the aerial.
BazaJT
Of the options posted above I'd be inclined to go for aerial problem.If I select a channel that's not available in my area it just shows a blank screen and this problem only arose a few days ago prior to which the channels I mentioned were fine.I live in one of the inner bungalows of a row of four and my aerial is high up on the gable end of a next door neighbours outer bungalow so access to it is awkward.The aerial has always been where it is since before we moved here 11 years ago. But I'll look at that channel checker to see if that offers a solution.
Ask your neighbours if they use freeview, then ask them if they are receiving those channels ok
Diesel till I die
cam.in.head
channel 48 is always the first to break up on mine too and thats with a near direct view to emley moor . 99% of the time its fine so i just put it down to a weaker signal on that channel ( not that freeview will be around for ever if the powers that be get their way !)
Usual checks - retune, then see if all the impacted channels are on the same Mux, and if so, check the engineering page of your transmitter as it may be a Mux is on reduced power
Quote from: TheBoy on 02 March 2025, 16:52:30
The muxes carrying the lower budget channels often have lower TX power and / or less robust coding to cram more channels in, so they are often the first to deteriorate. They have also been retuned in recent years, so worth checking that the antenna is still targeting the right group.
BazaJT
Well I retuned and that made no difference so looked on their website which said all signals were good. There was the option to webchat but apparently they're only there Monday to Friday 9 to 5. Was going to do that later but checking again this morning and all channels are operating as they should.
ronnyd
Quote from: BazaJT on 03 March 2025, 08:02:55
I thought that AI never slept.
Lizzie Zoom
Have you checked the aerial though?  Check also all leads, and any booster if you have one Baza.  Has a bird or other animal damaged the aerial or leads?  I recommend you keep a very open minds as something has changed the signal quality.
If you can, get up onto where the aerial is on the roof and check everything out.  I have spent many a happy minute on roofs  installing / checking aerials as my ex was scarred of heights, so I did all that kind of,  high level work!  ;D ;)
ronnyd
Quote from: Lizzie Zoom on 03 March 2025, 11:01:05
Why, did he fall down and cut himself? Sorry Lizzie, couldn't resist.  :-*
Lizzie Zoom
Quote from: ronnyd on 03 March 2025, 11:36:27
;D ;D ;D  Well in a way he was "scarred" by being at height, as well as "scared" ;D ;D ;D
My spelling gets no better with age!!  ::) ::) :D ;)
Guessing you are on the Belmont transmitter given your location?
The channels you are having issues with are all on the same transponder channel (C23) and is a medium power one (the low power ones are for local stations only):
https://ukfree.tv/transmitters/tv/Belmont
Its possible if the antenna and/or cable is deteriorating then it will be the first to be affected (as its low power and low in the spectrum)
