Pages: 1 [2] 3 4 5 6 7 8 9 ... 16   Go Down
Author Topic: Massive Clattering Noise  (Read 96003 times)
Re: Massive Clattering Noise
« Reply #15 on: 07 March 2025, 09:44:53 »
From memory, 2 teeth is about the absolute limit you can still get away with it (sometimes) on those v6.
« Reply #16 on: 07 March 2025, 09:49:13 »
Yep 2 x E14 for tensioner assembly :y
I think a belt tensioner / idler has let go on the Cambelt setup and slipped out of time
Summer is coming, if the belt has slipped and bent valves we could do an OOF top end overhaul on this for nostalgia sake :y
As it was during idle speed, I think the piston crowns will be fine, so damage limited to top end.
When the Cambelt failed on my 3.2 the pistons were fine - have driven it to Gibraltar and back since then! :y
Dave_G
  • Nottingham
    • 2002 2.6 Elite Estate
« Reply #17 on: 07 March 2025, 12:35:54 »
Thanks for that Countrywoman - cheered me up no end!!
And yes, E14 is more like it.
I dropped a socket in the underpan and when I fished it out with a magnet two steel pins came up too. About 12mm long by 4mm in diameter. If they’d been there for any length of time they’d have dropped out. Could this be related to something?
I’m going to have a hard think about what to do next. My ambition may have exceeded my ability here…
countrywoman
  • worcestershire
    • skoda yeti
« Reply #18 on: 07 March 2025, 13:40:39 »
Sounds like needle roller bearings------------
    • Grandland 1.5 diesel
« Reply #19 on: 07 March 2025, 14:15:17 »
Yep.
Diesel till I die
Dave_G
  • Nottingham
« Reply #20 on: 07 March 2025, 14:48:51 »
I thought they might be locking pins to secure a gear to a shaft somewhere. Like a keyway but through the centre of the shaft. But there were only two.
Do the camshaft pulleys use locking pins like this?
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
« Reply #21 on: 07 March 2025, 14:55:19 »
dont jump to conclusions just yet . lets see what you find once the cover is off !
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #22 on: 07 March 2025, 14:55:44 »
Don't knock yourself, you've done well to get this far.  :y  At least get the cover off to see what let go. It'll bug you otherwise.  :)
« Reply #23 on: 07 March 2025, 15:25:32 »
Did they look like these?
Diesel till I die
« Reply #24 on: 07 March 2025, 15:44:09 »
But you're on a forum of people who know these cars inside out, and will be wiling to roll up their sleeves - especially with the warmer weather coming :y
Dave_G
  • Nottingham
« Reply #25 on: 07 March 2025, 15:59:06 »
The pins do look like those Stemo.
As I say, 12mm x 4mm diameter
« Reply #26 on: 07 March 2025, 16:52:34 »
It's no use guessing, you're going to have to strip it down as far as the cambelt
Diesel till I die
Dave_G
  • Nottingham
« Reply #27 on: 07 March 2025, 18:19:11 »
Here's those pins.
Oh Lord I hope this works, otherwise 40+ years of software development have just gone down the toilet...
https://i.postimg.cc/sX2wRN5p/Pins.jpg
« Reply #28 on: 07 March 2025, 18:41:48 »
Here's those pins.
Nope  ;D
Diesel till I die
cam.in.head
  • West yorkshire
« Reply #29 on: 07 March 2025, 19:01:59 »
cant think of anything in there that has a needle roller  bearing on it ??
the tensioner and guide bearings are ball bearings , as is the aux tensioner .
are we into the belt area yet and howz it look ?
Pages: 1 [2] 3 4 5 6 7 8 9 ... 16   Go Up
Page created in 0.023 seconds with 21 queries.
