Small shopping list of bits I want...
Started by GastronomicKleptomaniac, 13 April 2025, 15:39:56
I'm after the following, preferably in plod black but I'd also consider the real and authentic wood effect.
All to suit a facelift manual saloon.
Centre console/ radio surround
Ashtray cover
Gearstick surround
The little black frame the gear gaiter attaches to
Set of front window switches, if anyone has the driver's switch panel for a GLS/Special that has only the two fronts? I'm after a front passenger side switch in any case.
Probably a few more bits as well.
Let us ignore the fact that one of the cars currently has no engine, transmission, or suspension, I'm prioritising here!
TIA :y
Start with the hard to find bits ;)
If it helps, the passenger front switch is the same across the range and '99-'02 GLS only had front electric windows. They also had the black/charcoal trim and also more likely to be manual although the centre console panel is the same across the board.
Have used this to good effect...
https://www.ebay.co.uk/itm/203550624822
Just prep the surface properly and it coats well and is reasonably scratchy resistant... I used it on my door cards after removing the soft coat, so can vouch for it :y
Good shout on the GLS trim also being dark.
I have a full set of silver MV6 trim but in my stupid brain that's too rare to sand and paint, so it will just sit in a box in the spare room...!
Never thought of using Tamiya paint, I might give that a go! Cheers :)
countrywoman
Cleaning my workshop and found the centre console , black ex plod just the main bit if you still want it.
Quote from: countrywoman on 08 September 2025, 17:44:48
Haven't been on for ages, but yes please!
