Author Topic: Serpentine belt guide  (Read 6801 times)
mong00sehun
  • Hungary
    • 2.6 V6
« on: 14 May 2025, 11:19:56 »
Hi guys,
Is there a serpentine belt change guide? I didnt find any.
Thanks
Re: Serpentine belt guide
« Reply #1 on: 14 May 2025, 12:00:13 »
Not that I'm aware of.
On a 2.6 - from your profile - you don't have to worry about the SAI stuff, so should be a bit easier, and from memory can be done with bagpipes still in play.
So,
Photo/draw the route of belt
15mm socket on a breaker bar, attached to tensioner (top left pulley looking at engine), and turn it clockwise to loosen tension, and unhook belt.
New one fits in reverse manner.
I've got an inkling that 1 T8 torx has to come off from a bracket near water pump, or am I thinking of the 2.5/3.0 engines?
Now, if you can grab some photos and do a guide for others, that would be appreciated :)
mong00sehun
  • Hungary
    • 2.6 V6
« Reply #2 on: 19 May 2025, 20:50:58 »
thanks for the quick guide, i changed the belt. i made a lot of photos, so i will write a guide sometime.
i made a quick video about the new belt, please check it, and tell me if something is wrong
https://www.youtube.com/watch?v=iczQ8ju9fB8
thanks for the help  :D
« Last Edit: 19 May 2025, 20:52:33 by mong00sehun »
« Reply #3 on: 20 May 2025, 11:57:40 »
Looks Ok to me, apart from your steering wheel is on the wrong side of the car, obviously...
Belt looks fine :y
