Further ABS fault
Started by countrywoman, 08 June 2025, 16:16:01
countrywoman
Okay so got my Snap On code reader working, it says fault code 35 pressure release relay fault. (same as Ds diagnostic tool) so does this mean it needs a rebuild? I take its not referring to the 2 50amp electrical relays on the top?
That sounds like a red herring  :-\
countrywoman
So do I have to send it off to be checked out, TBH its been sat over 20 years.
Quote from: countrywoman on 09 June 2025, 17:44:03
Wouldn't be the worst idea unless the wiring diagrams clearly indicate what/where the pressure release relay is for testing purposes.
countrywoman
Just found an online Vauxhall repair manual, PIA to find what I wanted but it said code 35 due to pump not making pressure after 3 secs or pump not turning off. Looks like it will defo have to be serviced.
cam.in.head
is the unit fully installed and bled ?
GastronomicKleptomaniac
Quote from: cam.in.head on 11 June 2025, 11:56:08
Oh! I wonder if it needs connecting to a Tech 2 type thing to cycle the pump to get the air out to allow it to build pressure:/
Quote from: GastronomicKleptomaniac on 11 June 2025, 13:11:16
Surely a snap off scanner should manage that :-\
countrywoman
Thats my task for Fri, well check the pump runs first!
Quote from: Doctor Gollum on 11 June 2025, 13:18:32
I don't use anything more nuanced than a hammer so no experience, anything like that I visit my guru :D
countrywoman
Well neither my scanner or Ds modern one will support activation of pump, tried to get the relays out to bridge pump feed but only the top came off one (not the one I wanted) and the other refuses to budge. D will see if the folks he sends ABS units to can fix this one on Monday.
countrywoman
Its working, yup works better with the earth lead on the motor!!!! I know why I missed it as unit fitted before engine and it was hidden, only saw it today as doing some checking /snagging jobs and was lay underneath.
Migv6 le Frog Fan
Been there, or similar at least. You dont know whether to laugh ,cry ,or do a silly dance.  ;D
LOL, nice easy fix in the end ;D
countrywoman
Yes but now it says brake switch fault but that works , checked the wiring and all looks okay. Brakes do need bleeding as a bit long travel when servo working. Only 2 wires on switch by the way.
