Author Topic: Radiator plastic  (Read 33247 times)
chrisr
    • 02 2.2 petrol
Radiator plastic
« on: 13 July 2025, 14:19:07 »
Can anyone tell me what type of plastic the sides of the radiator are made from, I have a crack near the top hose which is weeping. I have some Plastex to repair it but it says it will not adhere to polypropelene or polyethylene.
Has anyone successfully used Plastex or anything else for this?
Thanks.
Re: Radiator plastic
« Reply #1 on: 13 July 2025, 16:11:43 »
Not sure to be honest, but nothing I've ever tried fixes those types of cracks, so I've always replaced the rad when it happens.
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
« Reply #2 on: 13 July 2025, 17:58:56 »
as a quick "get you home type fix" you could melt the crack with a small soldering iron and maybee overcoat with jb weld or similar but it probably won't last long term and new rads are not that expensive .
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #3 on: 13 July 2025, 19:43:44 »
plastics are notoriously difficult to glue, and that's before they've had twenty years of heat cycles and chemicals flowing through them.
When a brand new radiator is about £100****, gluing one should really be considered nothing more than a get-you-home lash-up
**** Or much less; LINK
chrisr
    • 02 2.2 petrol
« Reply #4 on: 13 July 2025, 20:16:11 »
Thanks for your replies, I already have a replacement, I was just trying to put off doing it as I need the car a lot at the moment, plus something is bound to go wrong!
  • Chatham, Kent
« Reply #5 on: 13 July 2025, 21:32:57 »
If you count the time needed for any adhesive(that might work) to set, changing the radiator will be quicker.
omega2018
    • MercCL500 Omega2.6ManElit
« Reply #6 on: 13 July 2025, 21:55:52 »
Won't be polyethylene or polyprop which are both low melting point and quite oily plastics hence very difficult to glue.  It's probably glass re-inforced nylon.  As a temporary repair I would use a plastics epoxy eg Unibond 1381190 Repair Power Epoxy for plastic.  You might find the repair outlives the rad but I wouldn't rely on that. Clean the joint with meths beforehand.
chrisr
    • 02 2.2 petrol
« Reply #7 on: 14 July 2025, 04:43:18 »
I can't find a guide anywhere on the forum as to how to replace the radiator, is it straightforward and is there anything else I need other than the new radiator? Thankyou. 2.2 Petrol
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #8 on: 14 July 2025, 15:20:37 »
Pretty straightforward. Its just nuts, bolts & screws really.
If it has a transmission cooler built into the drivers side it would be advisable to get four copper crush washers for when you reattache pipes to the new rad.
Apart from that, just some new coolant.
Steveplumb
  • Radstock, Near Bath
« Reply #9 on: 15 August 2025, 08:55:25 »
I had this exact same situation last week. the crack was near the top hose . so with the hose removed from the rad the crack was accessible from the inside ,  I bought a tube of hybrid adhesive/silicone  and applied it liberally over the cracked area with my finger. It is definitely a short term fix but   much better than trying to bond from the outside. On the inside the silicone is pushed on to the crack as the pressure builds.  so far it has held, but new radiator is ordered !
