Polar Blue '96 3.0 MV6
Started by Valentin, 01 August 2025, 11:45:47
Valentin
Hi folks !
As described in my presentation I bought this blue whale in March and so far it's a really really good car. I never thought it would be so good at any levels.
All started when I was with some friends in Millau for a trip, and we where talking about a Vectra GT (SRi) that I missed to buy because the owner changed his mind every week, and finally increased the price like 3 times... But as we say here (and maybe over there) misfortune of some, makes happiness of others. Because the same day one of my friend found this Omega. I sent a message to the owner to have some more info, and the deal was almost concluded. The car was sold by the owner's wife as he passed away few months before. The car was 600kms away, in the city my father was born, how funny! By searching the names and dates, we found out that maybe my grandfather and the Omega owner could have been friends, because they lived in the same street as kids. We will never know, both are no longer here to tell us ;(
We set a rendez-vous at the end of March, I called a friend to come with me and come back by the road with the two cars.
Here we are, we stopped over my friend's family to sleep overnight before going home.
First impression of the car : it's comfy, seems heavy compared to my GTC, and I can feel something is wrong with the diff. After the diff is up to temperature, we can feel the teeth vibrating in the car when we make 90° turns while accelerating. I was not aware of the LSD at this moment, then I found that every 3.0 and 3.2 had one. My friend was jealous :D because he doesn't have one on his 996 3.6 :P
We took care of corners after that, trying not to put any gas while turning. It was a bit tricky but it worked. Green light, accelerate enough to have inertia, release, turn, accelerate again :D same story in the roundabouts.
Journey to come back home was lovely, weather was great, we drove over Paris external peripheral area. It was great until we found out the stop lights never worked... And so was the cruise control disengage function while braking  :o
My friend who was driving the Omega at this moment, had a moment of panic because as he was braking hard arriving near trafic jam, the car downshifted and accelerated harder to reach the set speed. As he was not familiar with the stalk button, he shifted to neutral. Sounds like a movie, right ? ???
Another small annoying thing was the sample fan in the central dashboard. It was so noisy! I didn't know what it was at first, fearing something very bad in the climate control unit. In fact... no ;D
Finally arrived home around 7pm. Oh I forgot to say, there was no mention of timing belt replacement in the last years on the bills history (the Great Book of Bills, 273 pages) I got with the car  ;D Last replacement seemed to be in 2013. ???
Valentin
What has been on the list in April / May :
- Timing belt kit - OK with Gates
- Water pump - OK with SKF
- Oil diff change - OK with Castrol Transmax Limited Slip 85W-90
- Oil engine change - OK with ISOTech 10W-40
- Replace the stop switch - OK
- Fix the sampler fan - OK, just the small axle lubrication
- Replace the 4 speakers door, they were completely torn - OK
- Replace the climate control unit bulbs - OK
- Recharge the AC gas - OK with EazyKlima cans
- Clean the leather - OK
- Install a bluetooth receptor wired on the R/L CD changer input at the back of the radio - OK
Some pictures of what has been done until today :
Diff oil
Timing belt, it was clearly TIME TO CHANGE!!! (this one was at least 12 years old and more than 80.000kms)
Stop switch, that little thing was worn inside, and never went back to its normal position. New one fixed all the issue linked to it.
While working on the timing belt, I checked the cooling system and I think it needs to be fixed as well. Too much coolant build up in this area...
I bought a pair of '98 headlights without xenon. The goal here, totally refurbish the units and properly fit bi-led lenses. Something I already did on my Calibra and the result is astonishing.
For now they are waiting, I need to make the spacer for the new bi-led lens.
Talking about cleaning now, first time with leather seats, first time with clear leather. I just took a medium polishing pad with a soft leather cleaner, cleaned gently and the result is perfect!
Then the carpet with an injector/extractor
Nice and clean
And one of the last big work this car deserves : body work / painting / detailing. Just to see what's possible on this nice Polar Blue. And I can't wait to be at this special step of the revival. Dent puller, paint, DA polisher they are all ready 8)
The bumpers are in pretty bad shape, as well as the front left fender. The rear passenger door is completely rotten on the bottom, maybe I'll have to replace it.
Just a try on the hood
Next steps :
- Unclog scuttle drain underneath the cabin filter - already done
- Fit z20let injectors to convert the X30XE to ethanol
- Replace spark plugs
- Replace front discs and pads
- Replace rear pads
- Replace the oil cooler with specific stainless steel custom parts from ACS
- Replace the thermostat
- Replace both complete tie rods
- Replace the blinker's stalk
And that should be good to take the road and drive 2400kms for the next trip :y
That's a beautiful car, love the colour :-*
You seem to be familiar with the omega, as well as other Vauxhall models, so it's good that you can do the work yourself. Paying someone else to do it would probably make it unviable. It will still be a money pit but, if you go into it with your eyes open, it will bring you years of comfortable cruising.
Diesel till I die
Valentin
#3
To be honest I was absolutely not familiar with the Omega. It was clearly out of my scope a few months ago. Actually, I was looking for a C5 Hydractive HDi. I make the Nantes - Nice journey once a month, and even if the GTC is very comfortable and has a lot of nice features, I wanted to preserve it from high millage.
But, you're right, I'm familiar with other Opel / Vauxhall :) and I can admit that the Omega is really in a higher level regarding the quality of fabrication.
Clearly, this car would cost a lot if I would bring it to the service repair. Doing it myself is an unexpected learning experience. :y
At the end, when the Omega will run on ethanol, it will cost the same as my diesel GTC, with the V6 sound and smoother suspension  8)
Clarkey
Fantastic looking machine and very satisfying to see one in such good hands. You have a real solid car with a great spec and are doing everything the right way to get many more years motoring from it and with way more comfort than any other Opel model on the road. Health to drive.
Rangie
What a lovely example & a great colour your car is , they were a very good looking car & still are in my opinion, always regretted selling mine I was tempted by a V8 Mercedes but in all honesty the Omega was a much better car, keep it for as long as you can.
That scrubbed up nicely.
I'd probably go and buy a lottery ticket after surviving 600kms on that cambelt :o
BazaJT
Looks a nice example benefitting from your time and effort. Lovely colour combination too.
Valentin
Thanks for all the messages :y
I recently received all the parts needed to :
- Change front discs and pads
- z20let injectors to convert the X30XE to ethanol
- Replace spark plugs + ignition cables
- Replace both came cover gaskets (Loctite 5923 sealed :y )
- Replace the thermostat + double o-ring from the pipe
- Replace both complete tie rods + eye alignment with this very helpful guide https://www.omegaowners.com/forum/index.php?topic=103468.0 (will need a better setting of course but it's so much better than before just with this little tips)
They were stuck, a good heat gun focused on the out cylinder of the disc and a good hammer + WD-40 eventually had them
Grease on the lip only (M539 Restorations best advice), brand new ATE discs and Brembo pads.
I replaced the complete tie rods because it was impossible to move the previous ones, even with WD-40, heat, vice grips... Easy task, and this is Moog parts
The ACS stainless steel oil cooler received from Ukraine, the part is 113€ :) , with 40€ shipping ??? , and 30€ custom fees ;( >:(
But it fits perfectly and is lifetime guarantee
After some hours to remove all the intake assembly, here we are. I must admit that I was not prepared for such a painful journey. Regardless the oil cooler, just to replace the ignition cables for example, it's clear that the engine and cable management was made for factory assembly, but absolutely not for maintenance ! This engine is way more difficult to work on compared to the same V6 in a Calibra / Cavalier :o The left bank cables can witness, they were from factory, never changed. They were inside the original gutter, clipsed to a plate, impossible to see, that I by magic managed to unclip just by the feeling of the pliers. On the right bank, one was from factory too. And the fact that the whole engine wiring running on the right bank must go out of the gutter to be able to change 3 spark plugs is insane. That car is unbelievably good but this particular case asks the question : Dr Indra Fritz (who made the c20xe) was the guy behind the x30xe, but it's clear he was not in charge of the peripheral elements :D Who is the person in charge of this back in the days? He deserves a medal of chocolate...
New oil cooler ready
For the washers, Opel cannot provide them anymore. I took the original ones that were torn (bi-material) and went to a truck hydraulics specialist. He gave me something from Iveco that was quite the same. Every bolt and washer from the coolant bridge and the oil cooler has been secured with Loctite 5923 on the contact faces. I didn't want to undo all that work for a leak :D
Came cover gaskets replacement
z20let injectors (I didn't take specific photos of that part)
New thermostat
The car now runs under ethanol and consumption is about 13.7L/100km with city and very dynamic drives (10.3L at the board computer). Yesterday I drove 1h30 on the highway, board computer says 8.3L. Then I will calculate at the next refill :y
Great to see an omega brought back to life  :y That's one of the good examples that is definitely worth doing. Unfortunately, some of them are too rusty to be viable.
Diesel till I die
Valentin
Some work has been done since the last time :y
There will be a lot of pictures, sorry ^^
Steering Wheel Control retrofit with new radio unit (JVC with Connects2 module, DAB antenna, color matching)
Fully refurbished second hand leather from a '97, didn't want to change the airbag so I cut the openings for the switches inside the foam/plastic, identical cut line compared to the donor steering wheel.
Nice weekend with friends in December (3.2 Executive)
Found out my tyres were worn to the wire on the inside edge, decided to change all drop links (left side was shot) and control arms + full wheel alignment with WIM values
Bi-led lenses retrofit into lenticular halogen basic headlights
Custom made stainless steel adaptors for the specific lenses
Polycarbonate lenses are burned, even on the inside, even after new 2K clear coat. Might change them later.
Last adjustments, not without pain i'd say :D
Low beam
High beam
Spread the light like a modern Mercedes, line cut perfectly horizontally :y
And last week was the paint party!!!
Reshaped the corner aside the headlight and one rust point under the passenger front window lip :
And... I had some activated 2K clear coat left, didn't want to throw it away so, I quickly painted the bumpers :-\ not convinced but it's not a showcar and it's made to hit the road
Also replicated those clips in 3D printing
Pictures of the complete car in the next days :y
Valentin
Some news about the blue whale, she offered me a nice surprise at the top of the Croix Haute pass 2 weeks ago as I was on the way to Nice Cote d'Azur on a Sunday quiet drive. The climb to the top of the pass achieved the radiator that probably was already dying from few weeks ago, but I didn't find out because it was under the plastic cover near the battery.
When I stopped on the car park, stayed with ignition ON and engine OFF to keep water flowing through the electric pumps and full speed fans. Temperature almost reached the red zone, the light didn't switch on tho. When I opened the hood, there was a crack near the top rubber holder that was spraying water and steam, there was still water in the cooling tank, but quickly all the water dropped on the floor and I could hear boiling in the engine bay. I immediately refilled with water and started the engine 5 seconds to flow it through the engine, temp eventually reached 90°C and the spraying crack became quiet.
I was stuck right here https://maps.app.goo.gl/GRp477yQoz9MGgyH9
Here was the situation : I was on the way to go to work in the south for 5 days. Omega was game over after 1h30 of driving. My GF proposed to bring me there (where I have a car for the commute workplace - accommodation), she made 660km round trip just to bring me to my workplace  :-* and then, I had 4 days to find a radiator for X30XE autobox + AC.
I found a very good local specialist shop, who managed to deliver the new radiator in less than 24 hours on the Tuesday. Found a BlablaCar for the Friday back journey, brought some tools with me and managed to change the radiator on the carpark at the top of this pass :y
The car started perfectly, I was worried about head gasket damage but after one heat cycle with fans doing their job and water cap open, their was no boiling, no pressure coming from the water tank. I closed the tank and waited 2 more cycles to be sure, then went back home with some 0 to 100 at highway tolls, absolutely no problem. After cooling 2 days resting at home, there was no pressure in the water tank.
Even so, Omegas in general tend to heat very much when exterior temperatures reach above 26 / 27°C on the climbs. I know the gauge is not a good reference and I should plug the "My Naff Code Reader" to know exactly the engine temp, but still, is there a radical modification that can solve this behavior?
PS : sorry for the pictures in the previous post, I don't know why they are broken, it's a shame because they could have been helpful to anybody ;(
That cracked plastic is really common on Omegas, and many other cars, as the radiator ages (all rads used by manufacturers are made by a handful of companies like Hella, so all suffer equally).  I'm sure the replacement rad will be good for at least another decade of heat cycles :y
In modest climates, its probably first noticed by having to top the coolant up occasionally - this is the warning that needs to be heeded, else you could end up stranded.
Driving up a pass is obviously putting a lot more heat into the system.
In my experience, its actually hard to cause a HG failure on the V6 Omega through coolant faults, unless you're being a bit daft.  Most are due to poor coolant (or servicing), and of course the 97.5MY 3.0l pop them like a Rover K series.
