02 plate mv6 for sale / spares or repair
Started by tigers_gonads, 20 August 2025, 10:50:53
tigers_gonads
02 plate Vauxhall omega 3.2 Mv6 Estate
173K
Good Bits ...........
Full manual conversion (R28 box / cut not forged gears)
3.9 rear diff (auto to offset the lpg tank weight)
Cat's still fitted.
Full Stag LPG Kit with in date doughnut tank in spare wheel well.
Rear doughnut bushes replaced with Poly bushes.
Front wishbones Poly bushed.
Eibach lowering springs fitted to the front.
HD standard height springs fitted to the rear (too offset the weight of the lpg tank / Car sits perfect)
Bilstein B4 shocks on all 4 corners.
17 inch mv6 alloys 235/45/17 with Avon ZV7 tyres  (a good 7mm tread)  All airtight but scruffy
Engine very smooth.  Not Running due to suspect siezed starter solinoid but turns over via strongarm on bottom pulley.
Oil changes twice a year regardless.
Leather Mv6 interior. (needs a bloody good clean)
Tow bar / electrics
Bad Bits .......
Paint lacquer peeling on roof.
Scabby front wing and rear wheel arches.
Chassis never welded but 100% needed now.
No stereo or speakers fitted.
Door cards present but not fitted.
Rear off side wheel bearing fubar.
£250 Cash
tigers_gonads
