Author Topic: Clutch size .  (Read 31035 times)
Olympia5776
  • Ireland
Clutch size .
« on: 25 August 2025, 22:58:54 »
I've decided to recommission my '99 Omega 2.0 X20XEV .
I have to replace the original clutch as the bite point is almost at the end of the pedal travel even after bleeding the system several times .
The clutch size according to Haynes manual and most search engines that I have used show it to be 215mm dia with 14 teeth.
This is proving to be difficult to locate .
Kits sized at 220mm dia seem to be freely available but according to Haynes manual this size is for the larger engined models .
My question is will the 220 mm diameter clutch fit the X20XEV flywheel ?
Thanks .
    • Grandland 1.5 diesel
Re: Clutch size .
« Reply #1 on: 26 August 2025, 19:02:40 »
Is there no one that can help with this? :-\
Diesel till I die
Olympia5776
  • Ireland
Re: Clutch size .
« Reply #2 on: 26 August 2025, 20:36:14 »
Uhhhh....Thanks Steve , you're like a big brother ........
What a pita this is ...
Decided to recommission the Omega and enjoy it again before I get too old ....
The 215 dia clutch is proving to be very difficult to find at a price that is (even)  reasonable . I just don't want to get the 220 mm version and find that it doesn't fit when it's all in bits .
Anyway , hope you're well .  :y and thanks for the help.
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: Clutch size .
« Reply #3 on: 26 August 2025, 22:11:28 »
The 215 dia clutch is proving to be very difficult to find at a price that is (even)  reasonable ………..
Autodoc list a Sachs Clutch Kit in 215 with 14 teeth, but whether it’s actually available I couldn’t say. Might be worth contacting them.  :-\   It depends what sort of figure is considered reasonable I suppose.
Olympia5776
  • Ireland
Re: Clutch size .
« Reply #4 on: 26 August 2025, 22:26:01 »
I bought it yesterday along with a central slave cylinder and a timing belt and water pump kit .
Paid via PP and got a refund today for the clutch kit . They say that even though one shows as being in stock they have checked and there is none .
I sent them the VIN to see if they any others to suit and they came back with a 215mm plate and a selection of three pressure plates all of different manufacturer from the plate and no way of determining from the description if the PP dia  was sized to suit the plate .
I don't want to have to mix and match .
I also contacted my local GM MD and they offered me three different clutch plates but no pressure plate was available .
The clutch plates were of different sizes but they could not tell me what was what .
I've found one in UK and am awaiting reply to see if they can confirm it is correct even though the description says so . The reason for this is that they do not take returns and that's a risk .
Buying from UK is a royal pia as the cost goes through the roof due to import taxes into Rep of Ireland .
Ho hum .... we'll get there .
Thanks for taking time to check for me .  :y
YZ250
Re: Clutch size .
« Reply #5 on: 26 August 2025, 22:45:00 »
Ah, no good then. Hopefully something will turn up.
Olympia5776
  • Ireland
Re: Clutch size .
« Reply #6 on: 27 August 2025, 19:36:50 »
Right ... I believe I have the answer .
After much searching I found that the Sachs 220mm dia kit (3000 951 218)  is cross ref'd against two GM OEM numbers R9114941 and R1020061.
The former is a 216mm clutch and the latter is the 220mm version.
Both of these kits are suitable for the following engine codes ,
20 SE
X 20 SE
X 20 XEV
The Haynes repair manual gives three clutch sizes for the Omega 216 , 228 and 240 mm dia.
So it looks like the either the 216 or the 220 can be fitted to the 2.0 engine .
I can understand why so many suppliers were hesitant to confirm the suitability of either for my car .
The irony is that since I started this search I've found many more of both sizes available ......
Anyway , This may be of use to someone in the future who is trying to make sense of it .
Re: Clutch size .
« Reply #7 on: 27 August 2025, 20:30:13 »
That's great news, Don, you can get the old girl up and running. I must say, she looks almost brand new.
Diesel till I die
Olympia5776
  • Ireland
Re: Clutch size .
« Reply #8 on: 27 August 2025, 22:16:36 »
Thanks Steve , I'm looking foward to working on it and enjoying it again. Being at home nearly all of the time I need a good project to keep me going .
It's also a bit of inverted snobbery really as I still like using the old cars and van around town . :y
