Getting back into the Omega .
Started by Olympia5776, 26 August 2025, 23:15:45
Olympia5776
It failed it's annual test in '23 on high fast idle emmissions . I left it and then went back to it in March '24 and did the usual checks ,ran cat clean through ,new plugs /filters /oil / lambda etc...( all were fresh /new or almost anyway ) but it failed on exactly the same figures again with everything else perfect .
I just parked it up covered it over and left it in a corner of the garage .
Was moving it around last week and realised that even after 23 years I still enjoyed the car .
The years are passing all too quickly now so I figured I'd recommission the old thing and at least (try) and enjoy it for a while anyway .
I fitted new Bilstein B4's for the test in '23 and purchased a new certified 2.2 exhaust downpipe last year which I'm told overcomes the high Co reading due to the Lambda position being closer to the exhaust manifold and hence running hotter .
The timing belt has only done 815 miles since I replaced it four years ago but I'd never have peace of mind if I didn'y renew it and the water pump , its an hour and a half job on the x20xev anyway .
The cars done 28 K miles in 23 years with me and I've replaced the TB & WP 5 times . ::)
Clutch bite point is very high which is puzzling . I've bled the system twice but it's made no difference so that has to be done .
There's a great Opel / Vauxhall community local so it'd be great to get involved with them again , hence my wish to get it back on the road .
It's easy to forget how supremely comfortable these cars were /are . I have a new car and the seats are too firm and achingly painful after an hour .
Anyway , here it is in all it's glory .
Biased as I am I think they have aged well .
Migv6 le Frog Fan
Rangie
Great looking cars & that's a lovely example 👍
Still miss mine and it's a shame that they didn't make a proper successor.
I miss my Senator more than my Omega ....  ::) ::)
Quote from: Andy B on 27 August 2025, 18:01:11
Always preferred the Granada to the Senator, especially the later MK3 saloon. That said the facelift Omega B.was the car the.Scorpio should have been.
Quote from: Doctor Gollum on 27 August 2025, 23:31:43
The Ford designers must have been on magic mushrooms when they designed the Scorpio!  ;D
Quote from: Sir Tigger KC on 28 August 2025, 10:58:52
Perhaps he was the same dude who designed the Fiat Multipla. :)
cam.in.head
the granada  mk1 /consul was a fine looking car .and still looks classy today .
the early senators 'A' still look good not as keen on the senator b as it seems to look its age like the mk3astras did !.
omega is timeless as DG says yes .but only in FL versions i think ?.
Quote from: cam.in.head on 28 August 2025, 12:13:07
I'd contest that  ::)
Quote from: Andy B on 28 August 2025, 14:54:02
Of course, but you also only have two feet and your left one doesn't work >:D
Quote from: Doctor Gollum on 28 August 2025, 15:10:00
Quote from: Andy B on 28 August 2025, 14:54:02....
I was really referring to looks of the original cars vs the facelift .... I liked the swage line across the front of the bonnet & the FL looked too much like an Astra G  ::)
Left foot doesn't work?  ??? That's the foot I use to brake with.  :y :y :y
I find the pre facelift trims quite fussy and a bit dated compared to the timeless and more subtle look of the facelift tbh...
But horses for courses ;)
