Author Topic: Fuel level tank  (Read 45133 times)
Valentin
  • France
    • '96 MV6
Fuel level tank
« on: 01 September 2025, 15:37:57 »
Hi everybody,
I don't know if it's the car normal behavior but I find the level gauge a bit pessimistic. Over the total 75 liters, when the dash lights on and the board computer says less than 100km left, I only refill 55 to 62 liters every time. You can drive way more than 100km with 15 to 20 liters :o
It seems difficult to know if it's the gauge and light that is out of range, the level sensor in the tank, or the tank vapors that blocks the fuel gun  :-\
Have you already seen this kind of gap when you refill ?
Re: Fuel level tank
« Reply #1 on: 01 September 2025, 17:44:49 »
As both the fuel computer and gauge are wrong, the sender is most likely, or corrosion or other continuity issues along the loom.
Re: Fuel level tank
« Reply #2 on: 02 September 2025, 20:13:18 »
Didn't think the Omega tank was that big :-\
Thought 65/70 litres saloon/estate...
    • Grandland 1.5 diesel
Re: Fuel level tank
« Reply #3 on: 02 September 2025, 21:14:44 »
Fuel Capacity   75 litres
Weight   1705kg
Length   4819mm
Width   1960mm
Height   1545mm
Wheelbase   2730mm
Turning Circle   10m
Diesel till I die
Re: Fuel level tank
« Reply #4 on: 02 September 2025, 21:53:54 »
Fair dos ;)
Re: Fuel level tank
« Reply #5 on: 03 September 2025, 11:35:27 »
And the saloon would defo take all 75l.  Fuel station roulette to perfection!
Enceladus
  • London
Re: Fuel level tank
« Reply #6 on: 07 September 2025, 14:16:46 »
What happens when you fully fill the tank? Does the fuel gauge read full, or just under?
Valentin
  • France
    • '96 MV6
Re: Fuel level tank
« Reply #7 on: 08 September 2025, 14:48:39 »
The fuel gauge reads full :y
Page created in 0.241 seconds with 20 queries.
