Vectra B Xenon headlight levelling motor
Started by j3lly, 02 September 2025, 08:50:05
j3lly
Is this where headlight levelling motor lives
Can it be accessed with headlight in car
Can the levelling motor be serviced
TIA
Not familiar with Veccy-B but that looks like the actuator for it.  I suspect the system is identical to Omega-B, where those actuators are normally bulletproof unless they've had water ingress (when the motor corrodes and seizes solid)
What is the error you are getting?
j3lly
I had an issue with them not sweeping
Strngw thing is never had Fld/Warning come up on MID
I serviced both levelling sensors ( stripped lubed reassenbled )
Had a general poke around and clean up
Which solved the sweeping issue
Just thinking that if i seviced to levelling motors that would be everything serviced
Sweeping up and down? They don't sweep side to side.
Check the adjusters aren't broken (does back of headlamps unit flop about with quite a lot of play?
j3lly
They are sweeping up and down as expected
Nothing appears loose on back of head light
I can hear levelling motors cycle when ignition is activated
Just wanted to know if I can access levelling motors to service them
I believe it's remove headlights and seperated lenses from body to access
So will not be doing that then
Thanks for replies and help
Quote from: j3lly on 03 September 2025, 13:27:01
I'm confused, whats not working then?
That motor unit you circled unclips by turning 30 degrees or so, when pulls out. The motors are in that unit.  They are generally not servicable as in all cases where the motors have failed that I have seen, its been due to corrosion, too far gone for any sort of repair. You would simply replace that entire motor unit with a known good one.
