Author Topic: V6 camshaft sensor  (Read 60757 times)
mong00sehun
  • Hungary
    • 2.6 V6
V6 camshaft sensor
« on: 15 September 2025, 23:03:55 »
hi guys,
car made a big crack sound when staring, and since then the little car icon with the wrench is on, so the lump mode too (error code 340= camshaft sensor), and its limiting the engine to 4000 rpm
i cant find V6 camshaft sensor guide,  so where should i looking for it?  ::) 2.6 V6
Re: V6 camshaft sensor
« Reply #1 on: 15 September 2025, 23:47:33 »
The assumption here is that the sensor has failed...
Don't drive the car another inch until you've checked the timing.
The sensor is easy enough to change. But in this case it wouldn't be my first check.
If you do start with replacing the camshaft sensor, and again , I wouldn't under the circumstances, swap it with a known good one. From memory it can be replaced without taking anything else off. It's on the left hand cylinder head towards the front. Plug is next to it in the cable tray.
Good secondhand genuine one will be fine, but if you insist on getting a new one, then genuine or Bosch only. Don't waste your time on OE equivalent aftermarket rubbish.
« Reply #2 on: 15 September 2025, 23:49:33 »
I second Docs post, if the car made a horrible mechanical noise, then don’t even turn the key again until the timing belt setup has been checked.
Not just by peeling the cover back a bit, but by properly removing it, and checking the tension and timing is totally correct and no FOD
mong00sehun
  • Hungary
    • 2.6 V6
« Reply #3 on: 16 September 2025, 01:24:04 »
thanks guys
it was only one cracking like sound maybe it was just only the starter, because after that, the engine started normaly, sounded good, had the same power, nothing rattling sound, but i will check the timing
« Reply #4 on: 16 September 2025, 09:44:59 »
Ignoring wiring damage, I've never seen a Omega V6 cam sensor failure.
So if you have a P0340, you need to confirm that the sensor's wiring isn't damaged (usually caught under cam covers if those weren't replaced correctly) or check the cam timing.
Heed the warnings given by others.  Even if the cam timing is spot on, checking will give you that piece of mind :y
Incidentally, the cam timing can only be properly checked using a proper GM V6 cam locking kit. You can just about check its near enough not to cause damage without one, but you cant properly check or adjust it without.
« Reply #5 on: 16 September 2025, 10:13:22 »
I've replaced a couple, including one of Josh's.
Had it been a 2.2 then I would be suspicious as to the actual cause, and in this case the unusual noise was more of a concern.
mong00sehun
  • Hungary
    • 2.6 V6
« Reply #6 on: 21 September 2025, 18:30:35 »
hi guys,
i've been able to change the sensor, the car now is works alright
but this is the second time when the car stopped beacouse of some kind of sensor error. :( first crankshaft sensor, now camshaft sensor. is there any essential sensor that, if it fails, will cause the engine to stop?
« Reply #7 on: 22 September 2025, 01:58:33 »
The crank sensor will on a V6.
 Cam sensor tends to be more of an annoyance that catastrophic, although a code can indicate a jumped belt.
The fuel pump will kill it dead when it fails completely but you usually get fair warning by way of spluttering under load.
