Wtd - metal clutch fluid pipe from master cylinder
Started by GastronomicKleptomaniac, 24 October 2025, 12:08:20
Work continues apace. Found the metal pipe that goes from master cylinder to the rubber clutch feed is goosed. 2000 V6 if it makes a difference. If someone still has a stash that would be useful...
Or are they the same across all manuals? In which case I may try my luck with a breaker.
I assume they cannot be repaired as the fitting is weird.
