Author Topic: YaBB.pl files  (Read 4397 times)
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
YaBB.pl files
« on: 08 November 2025, 17:19:14 »
Hi folks....
I have what seems like a couple of bulbs out on the dash, behind the speedo. I have gone through the Search system, and there are some links on how to do the job. However, when I click a link, I get a download Yabb file. Is this where the instructions are hiding, and if so, how do I open the file !!!! ;)
Re: YaBB.pl files
« Reply #1 on: 08 November 2025, 21:35:55 »
In short.
Wheel to lowest setting.
Remove column shroud to easily access the screw retaining the filler panel and bottom edge of cluster... Be careful as if it drops it can land in the upper column pivot joint.
Tilt the centre vents up or down and pop out.
Remove the two screws now visible.
Undo the screw at the inboard end of the cluster.
Pull cluster out unplugging the MID/TID/Nav display as you go.
Bulbs are then easily and obviously accessible  :y
Refit in reverse etc...
Re: YaBB.pl files
« Reply #2 on: 08 November 2025, 22:00:11 »
Perl is broken on one of the web servers again, and it really is a PITA to sort out.  YaBB.pl pages are pages on your original software, before we changed to the current software about 15 years ago.
He is the link to remove the dash:
https://www.omegaowners.com/forum/index.php?topic=90505.0
https://www.omegaowners.com/forum/index.php?topic=90618.0
There is a brilliant index to common tasks as well - https://www.omegaowners.com/forum/index.php?topic=90633.0
If you get stuck removing instrument panel, pop round :y
Re: YaBB.pl files
« Reply #3 on: 08 November 2025, 22:06:43 »
You can probably also replace the www.omegaowners.com bit of URL which has YaBB.pl in it to oldsite.omegaowners.com which bypasses the (broken) redirect on our primary servers.
Its quite nostalgic looking around https://oldsite.omegaowners.com/forum/YaBB.pl ;D
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: YaBB.pl files
« Reply #4 on: 09 November 2025, 06:00:33 »
I agree, it is nostalgic.  :y  An awful lot of names from the past that are sadly no longer with us. Some very good help threads as well,  :y  and some very humorous threads.  :)
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Re: YaBB.pl files
« Reply #5 on: 09 November 2025, 10:03:55 »
Those were the days.  :y 8)
Still, its pretty remarkable that OOF is still going, over 20 years since the car was last sold and now very few left on the roads.
« Last Edit: 09 November 2025, 10:05:50 by Migv6 le Frog Fan »
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
Re: YaBB.pl files
« Reply #6 on: 10 November 2025, 09:46:39 »
Thanks for the replies chaps. Really appreciated. Thanks for your offer, TB…May take you up on that 😀👍🏻 I’m in Dorset until the end of the month, so won’t be around until then. Thanks for your fine explanation DG, but after my surprising success to change the wing, I think I have used up my cleverness for the time being. ;D ;D
Obvious next question, where do you get the bulbs from nowadays, or is it a scrappy job👍🏻
« Last Edit: 10 November 2025, 09:56:54 by Terbs »
Re: YaBB.pl files
« Reply #7 on: 10 November 2025, 11:05:54 »
Any auto shop (though get a feeling Halfords don't do correct wattage)
Is it backlights or warning indicator lamps that are blown?
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
Re: YaBB.pl files
« Reply #8 on: 11 November 2025, 09:18:29 »
It’s the lower part of the main display that illuminates the dials 👍🏻
Re: YaBB.pl files
« Reply #9 on: 11 November 2025, 18:32:43 »
Can't recall if they are a 1.2W or 2W capes type.  Reuse old bulb holder.
Re: YaBB.pl files
« Reply #10 on: 11 November 2025, 22:15:47 »
2.4w for the bigger ones iirc ;)
