Author Topic: Replacing rubber around windshield  (Read 4653 times)
Jan Suhr
  • Nyköping, Sweden
    • 2 Omega Caravans 3.2 V6
« on: 14 November 2025, 22:40:42 »
Got myself a "new" Omega in Germany a couple of weeks ago.
Really nice 2.6L and 99.9% rust free!!!
But there are a few things on it that bothers me.
One is the rubber stripe around the windshield, the one that go up the sides and around the roof line.
The current one has sort of dried out and cracked a bit. My old Omega is going to be scraped and picked for parts. The rubber stripe on that one is good and I was thinking that I could take that one and replace the dried one.
Is just to pull of the stripe and push it back on to the other car?
Thanks
Jan Suhr
Stockholm, Sweden
www.protouring.se
Re: Replacing rubber around windshield
« Reply #1 on: 15 November 2025, 00:28:28 »
If you're very lucky, possibly.
The frame pieces that the rubber trim clips into is attached to the glass with the rubber strip BEFORE the glass is fitted as the rubber is what sets the windscreen position in the aperture.
This is the only guaranteed way to get it fitted correctly. If you try and do it on the car you run the very real risk of pushing the frame pieces off the glass.
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
« Reply #2 on: 15 November 2025, 01:05:25 »
It can be done because I've done it.
To remove the good one, I would suggest using a pick tool to get the tongue started out of the retainer, and use some silicone lubricant to slide the pick tool between the lowest part of the tongue and against the retainer making sure that it isn't distorted. If it bends significantly (ie by pulling it up by hand) the likelihood it won't sit properly on refitting.
Make sure the tongue is spotlessly clean of any grit or crud, as  is the retainer. Lightly lubricate the tongue with either red rubber grease or silicone spray, position the moulding so that the top curve is exactly in position, the start gently thumb the tongue into the retainer at one end regularly checking that the top corner will still sit in the correct position. Go easy on it and take your time exerting a firm constant pressure as you go round the moulding, and it will go on easily. You will feel when it slots correctly into the groove on the retainer.
There is a good chance that some of the bonding used on the windscreen fitment may be in contact with and  support the retainer in part but don't be hamfisted and keep its profile as flat as possible when removing/ refitting and you should be able to do it ok
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
« Reply #3 on: 04 December 2025, 16:55:54 »
I have to add, that after a roof respray I have fitted a new rubber surround on mine. Took a bit of patience, the sides and most of the top went in ok, but one small section did not seat properly. Took a plastic hammer to it, a few gentle clouts and it seated just fine. I was using a new rubber, so can't comment whether it would be the same with a used one.  :y
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #4 on: 04 December 2025, 23:12:57 »
Where did you get it from please ?
I was under the impression they became very expensive and then no longer available.
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
« Reply #5 on: 05 December 2025, 15:55:20 »
What kind of Omega you are scrapping?
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #6 on: 05 December 2025, 21:03:32 »
I think I got it from E Bay mate, it was a while ago. I paid £60 for it. It was in a massive box obviously, as its posted as it fits on the car. It stood in our dining room for months before I actually got round to respraying the roof. I'll see if I can trace anything :y
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #7 on: 05 December 2025, 21:33:55 »
I didn’t get it from eBay, so I have no idea. I have just seen one advertised on a site www.mm-opelparts.com for £139. It says side/upper windscreen seal for Omega B.
Hope this helps. Sorry I can’t remember where mine came from ☹️
Migv6 le Frog Fan
« Reply #8 on: 06 December 2025, 11:32:43 »
No worries Terbs. Thanks for the info.  :y
Tbh, I think I would rather do without than pay £139 for a length of rubber though.  :D
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #9 on: 06 December 2025, 11:39:23 »
screen fitters have standard trim that looks pretty similar to the factory trim when fitted  :)
Migv6 le Frog Fan
« Reply #10 on: 06 December 2025, 12:28:58 »
Will bear that in mind next time a stone breaks my screen, thanks.  :y
« Reply #11 on: 06 December 2025, 20:53:10 »
It's not a seal.
It's, at best, a weather strip.
