Rear Abs pickup ring specs
Started by JamieC2311, 15 November 2025, 23:26:04
JamieC2311
Been looking for new abs rings for my rear shafts on my 3.0 v6 as mine are broke, checked all the usual places such as autodoc etc seemingly no where has any.
Came across these ones earlier, would any know if these will fit? I stupidly binned my broken ones so cant check ::) Thanks!
biggriffin
Hoof'land storeman.
JamieC2311
Would still need to take the rings off anyway as I'm restoring all components to like new
Russell WARD
I'd double-check the exact fitment before ordering, as ABS reluctor rings can vary depending on the model and year, even if they look very similar. Might be worth checking the part number against your VIN or measuring the shaft and the ring dimensions to make sure they're the right ones. AUTODOC is usually worth checking for compatible parts, but if they're not listed there either, a specialist parts supplier or an owners' group might be able to point you in the right direction.
