Author Topic: Y26SE Oil Leak around Oil Filter  (Read 3975 times)
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
« on: 01 December 2025, 18:18:11 »
Hello again
So V6 with canister type filter. The canister is dripping oil slightly. There is allways a drop when I take a look. Terrible place to study in floor but I took the whole canister off and found that the O-ring there against engile block was hard and brittle and tired. That is one possibility. I alredy have original spare for it. Cam covers are dry, checked with mirror. In canister area there are cooler pipes which may leak and also the area around crank sensor is wet. Any ideas how to proceed? Is crank sensor O-ring typically leaking in these enines and available separately? Does anyone know the size. I changed it perhaps 15 years ago. All ideas welcome.
Re: Y26SE Oil Leak around Oil Filter
« Reply #1 on: 01 December 2025, 20:07:55 »
You've answered your own question.
If it's leaking from the seal between the block and filter case, you have two options:
1. Replace the seal and ensure that the retaining bolt is correctly torqued with thread lock.
2. Convert it to a spin on filter.
Not sure why you would need to disturb the oil cooler plumbing to do either... :-\
polilara
  • Finland
« Reply #2 on: 02 December 2025, 05:11:35 »
Thanks DG, yes canister case is clear. I was just thinking "while I am there" whether I should check something else, too, as it is difficult to see where the oil is really coming from.
1. Is crank sensor going to oil area or is it in a dry place.
2. Tightening the oil tube fittings agains block was in my mind, perhaps I just damage them if I touch...
« Reply #3 on: 02 December 2025, 08:19:32 »
In this case, I'm of the opinion that you have most likely found the cause, and I'd just sort that.  Mainly because I have some bad memories of oil cooler pipes, lol
polilara
  • Finland
« Reply #4 on: 02 December 2025, 10:02:51 »
Thanks TB, better then not to touch them. Found spare number for the crank O-ring, does anyone know dimensions of that? 90307502
polilara
  • Finland
« Reply #5 on: 02 December 2025, 19:03:29 »
The leakage have bee somewhere for a while. Found also O-ring for crank sensor. When I put the canister back to block what is the tightenin toque of the central bolt?
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
« Reply #6 on: 02 December 2025, 20:35:36 »
bit late now but i was going to suggest not disturbing the crank sensor unless absolutely necessary !
i beleive it's the cable that gets brittle and fails on them
« Reply #7 on: 03 December 2025, 09:13:22 »
Additionally, I think oil leaks in that area speed up the cable's demise, base on my own personal experiences.
I would urge the OP to carry a spare sensor in the boot, along with the torx socket (E8?)!
« Reply #8 on: 03 December 2025, 09:19:12 »
Let me see if I can persuade my last remaining laptop running TIS to boot up
« Reply #9 on: 03 December 2025, 09:24:34 »
Ahhh, that sweet sound of XP booting up with an old mechanical disk drive ;D
It says:
Attach oil filter housing with a new seal (the large o-ring between housing and block) and tighten to 45Nm / 33lbft
« Reply #10 on: 03 December 2025, 10:14:23 »
I used to do that & when the CSS failed on my Omega I presented the recovery driver (there was snow on the ground & I had a caravan attached to the back of the car) with a the boxed sensor & told him the fault! His reply was ... 'no one has ever done that before!'  ;D ;D ;D
polilara
  • Finland
« Reply #11 on: 03 December 2025, 12:16:37 »
Thanks for torque info and other tips, too. Let,s see how it works.
