car stereo question
Started by cam.in.head, 07 December 2025, 16:50:49
cam.in.head
its certainly more fun than christmas telly !
LC0112G
None of the circuits seem to show a 'second stage of preamp' as such. The rcr87_essen circuits show the tape preamp (an RC4558) feeding a couple of transistors (V1120 and V1130 both BC549C's), and from there into the TDA7348.
This is also where the tape mute circuit comes in - transistors V1310 (BC808), V1311(DTC1432KA), V1312(BC848C) and V1313(BC848C). This is where it gets sort of interesting. The Mute circuit appears to be fed from a couple of microswitches mounted on the cassette mechanism, via connector P1350/N1950. It looks like pin 2 of this connector should go to +5V when the cassette is inserted. Pin 6 of the connector should be open circuit when not-muted, and shorted to ground by a second microswitch when muted.
It's not obvious from the circuits what controls the microswitches, but I'd guess it's loading and unloading the cassette tape. I'd be much more suspicious of these microswitches than any semiconductor device. Given the 'single fault affecting both L&R channels' issue, it's most likely the feed to the base of V1310 is dicky - from pin 6 of P1350/N1950.
cam.in.head
#32
hi and thankyou for all this .
i  mistook the other transistors as another amp stage !
yes the 4558 is the preamp ic and it all goes eventually into the 7348 .on one unit i have fed the head into a seperate preamp board robbed from a philips 752 and wired it straight down to the 7348  coupling caps.all works well so thats one unit sorted and proves im in the right area .
as for the other units i will now check the muting switches for any resistance leakage (or could i eliminate them completely ?
and yeah that 1350 plug contains the 12v motor supply and also two microswitches .one looks like it tells the motor to turn on and the other looks like it tells the system wether you are in play or fast forward/rewind and not play so yes i agree i this is the mute command ?
will have a play with this wire .thankyou again .will report back
cam.in.head
this also sort of ties in with the fact that even on a good unit if you get your finger close to that gren wire from the mute microswitch you can make it sound distorted but never saw the connection .!
cam.in.head
BUT  it also isnt a problem with the microswitch as such because ive swapped complete plug and play decks between units so more a case of an issue with the muting circuit itself .funnily enough of all the smt components that i swapped none of those transistors (or nearby resistors/caps )were touched!
cam.in.head
i think were onto something here !
after the connector on the board for the mute switch (the green wire switched to gnd) there is an inline resistor and then its straight to that first transistor .i have removed the resistor effectively taking the mute switch trigger out of the equasion .this appears to have cleaned the signal up considerably . so maybee that transistor had some leakage and was partly switching . i  beleive it might /shouldhave a resistor somewhere to keep it pulled off (or not?) but it seems like weve got it .no noticeable difference to how the rest of the unit works . was affected more in damp or cold weather so may have been partly switching that transistor on ? will try the one in the car on a damp cold day and then remove the resistor in situ and see how it sounds .
if this is the fix then you have solved me a problem that has been frustrating me for years and i spent a hell of a long time replacing stuff /swapping stuff i didnt need to ! learning curve or what !!
LC0112G
If I'm looking at the correct circuits - the resistor is R1310, a 1Kohm, connected between the base of V1310 (a PNP BC808) and pin 6 of connector P1530/N1530. When pin 6 of the connector is shorted to ground (by a microswitch on the tape deck) the transistor will conduct causing the mute circuits to activiate. The microswitch should be open circuit in normal tape operation. There is no resistor shown to pull the base high or keep the transistor "off", so the base is indeed floating during normal operation.
Lifting R1310, or disconnecting the wire into pin 6 of P1350, will have the same effect - and will stop the mute circuit from working. However, if that works it's not a leaky transistor - it's a problem with the wiring to the connector or the microswitch. However, it might be worth wiring a high value resistor (10K or more) between pins 3 and 6 on the connector. Pin 3 should be a stable 5V supply, and 10K should be more than enough to ensure the transistor (V1310) stays off when it should be off.
PS - I'm dying with man-flu at the moment, so might not be able to add any more unless I make a miraculous recovery.
this conversation went way way over my head pages ago!  ;D ;D ;D
cam.in.head
beleive me this has been screwing my head up for ages too . i started with this a few years back as one of my stereos went distorted .i bought another off ebay and the problem SEEMED sorted but i was curious what was actually wrong with the original unit .didnt realy find the faulty component then so gave up temporarily .THEN the same issue started happening to my other "same " stereos so i thought its a obviously a component that goes faulty with age .makes sense because they used to work and wouldnt be designed to not work right in winter !!
so now (if the problem is found ) il find out over the next few weeks, then although i still dont know which component is actually failing this workaround may just solve the issue anyway and doesnt seem to affect its functioning .radio plays fine ,cd changer and cassette and the display shows what it should and the selector switch does what it should .il try the suggested pull up resistor as the next stage if any issues present themselves .
a great big thankyou to anyone who helped especially mr LCO112G whom i am extremely gratefull to .
cam.in.head
ITS SORTED !
even cutting the track right at the transistor base and removing that resistor didnt solve it .that transistor is so sensitive ! you only needed to get your finger near it and it started to conduct! so i added a 10k resistor across its base and emitter .that keeps it at 4.9v and stops it picking up any interference or reistance to earth . i just confirmed it by putting the unit outside for a few hours .its quite cold and frosty here at the moment .just brought it in and in no time it was wet with condensation BUT CASSETTE SOUND IS STILL OK !!!
so il be doinn this mod to the others .thankyou immensly for your help .i wouldnt have thought of doing this .its either a design fault ,component of who knows what !!
the other issue of not always turning on is not as important now as ive now got useable spare units !
YZ250
Glad your perseverance and determination paid off.  :y
cam.in.head
yes i usually carry on until i find the problem .just didnt expect this to take a few years !. i couldnt have done it thou without mr lco112g whom ive probably srcewed up his head over this !
however ive learned a lot from him and im now going to have another go at thd original thread issue .(not turing on some of the time !)
i bought two units this month and added the pull up resistor to both of them as they didnt sound perfect in the cold bug now do .one of them however only turns on 9 times out of ten so im ready to bore you all on this issue  now !!!!!!!
LC0112G
The best circuit that I've found that most resembles your description is for the blaupunkt_rcr87_essen_rcr127. You can download that from here : https://elektrotanya.com/blaupunkt_rcr87_essen_rcr127.pdf/download.html
It may not be identical in every respect to your radio - but the tape and audio sections at least sound to be the same.
Once you've got the circuit it's usually fairly easy to diagnose audio faults, although it's much easier if you can follow the audio path through using an oscilloscope. More modern radios tend to be digital all the way through, so they are much more of  challenge, especially if virtually all the circuity has been integrated into a single chip.
cam.in.head
thankyou
will print them off at work tommorow and have a play !
cam.in.head
nothing obviously faulty standing out so i swapped the main 40 pin up chip.a heat gun with a shroud managed this ok .fault still remained so added a "reset' button to wake up the processor when it faults .this works every time it fails to power on so i can live with this .
put the reset button on the facia to short the control pin to gnd .works great and looks factory too !
so all problems solved realy .thanks to all for helping . cheers.
