car stereo question
Started by cam.in.head, 07 December 2025, 16:50:49
cam.in.head
hi .quick question regarding a car stereo .
what component on the circuit board is responsible of the turning on and off function when you press the momentary switch on the front ?
is it a chip or a type of transistor doing this ?
reason for asking i have a 90's blaupunkt in one of my cavs which turns on and off only when it feels like it
googling it or AI isnt too specific on this question either ??
cam.in.head
didnt there used to be a car stereo repair engineer on here once ?
Quote from: cam.in.head on 07 December 2025, 19:01:18
Dave DND
Diesel till I die
Diesel till I die
LC0112G
Lots of generalisations, but...
The switch is usually connected directly to a microprocessor (uP). The uP is powered all the time, even when the radio is off. There are usually several operating modes, including a sleep mode where the power consumed is minimised. Pressing the switch generates an interrupt which 'wakes' the uP up from sleep mode, and it then turns power on (or off) to the rest of the circuitry.
The uP doesn't actually switch the power - that is done by a separate power regulator/control chip. The uP simply asks the regulator to turn on or off. Older designs will be a simple 'on/off' wire from the uP to the regulator. Newer designs may have a digital comunicaiton bus between the two.
So, if it were me, I'd make sure the on/off switch is working correctly, and the on/off signal is getting to the uP. Not much you can do about the uP itself, but if you can find an online circuit diagram for your radio you might be able to find the connection from the uP to the power regulator. The regulator will be quite a large device usually bolted to the metal chassis of the radio. They dissipate a lot of power so get hot. You can sometimes read the part number off them and locate replacements.
Having said all that, if the radio is intermittent then chances are the uP and Regulator are Ok - silicon stuff is pretty reliable and unlikely to misbehave if correctly connected. It'll likely be a switch, crystal, resistor or capacitor playing up.
cam.in.head
thankyou very much for taking the time to write that lengthy reply .much appreciated .
so
its not the momentary power  switch for sure as its a removeable facia and the facia works fine on another unit .
i also have another unit that switches on and off fine but has other issues so was hoping i could swap the relevant parts(s) from that into my required unit .this is good cosmetically and has good cassette deck and cd changer  operation on it too (easier than swapping all these onto the other unit for sure !)
The era you describe is unlikely to be 100% mcu controlled, from personal experience, there is usually a transistor circuit that is used as de-bounce, I have seen these early SMT transistors go leaky and cause all sorts of random issues with operation (repaired many of the Vx high end stereos with this issue!).
cam.in.head
il have a play tonight .il open up the facia panel and see if the on off button goes to a specific pin and then follow it from there . like i say i have a unit that switches on off fine so the faulty part and its replacement are already in front of me ! .i just need to locate it !!!
Have you got any pics of which model it is ?
LC0112G
I have the circuits for the radio (SQR88?) and CD player (CDP09?) used in the LC - Both Blaupunkt blue dot. What model number radio are you having problems with? I might be able to get the circuits and have a look.
Mark is correct about the de-bounce circuit - but is depends on the actual fault. Are you saying when you press the on/off button it sometimes works, sometimes doesn't? Or are you saying that the radio randomly switches on some time (seconds/minuites?) after you have pressed the on button?
cam.in.head
sometimes the unit will switch on and work fine .sometimes it wont no matter how many times you press the button or how long you hold it .removeable facia (and another spare facia all work fine on other units )
it can work fine for a few days even .then one day its non responsive .rear iso connector is fine and powers and grounds are too.( bench testing same issue)
il get the model number tonight.there were quite a few basically identical units ,some with cd changer socket on the back and others without .all named after us places .
cam.in.head
this is all very much appreciated .
these units i had an issue with a few years back where the cassette sound was distorted and i swapped virtually every component i could on the board to eliminate it so it would be brilliant to gave a scematic for them with a clud as to what does what as i dont intend to change thses units .i have them in 3 different cars and likd them and they are not too flashy looking for an older car .they are in my two mk1 cavs and my 85 carlton .(2 using the boot mounted 10 disc changer)
cam.in.head
so this is how annoying it gets .wouldnt power up yesterday in garage.now set it all up for a bench test and it works .whats the difference ? warmer in house maybee ???
anyway ive opened up an facia and i think the first microorocessor is in there .it has a ST6240/c8 in it so maybee the power button triggers this and then the signal is fed into the main unit from gere .cannot find anything substantial on heatsinks apart from the two audio amps( TDA7375) so i will start googling chip numbers.
this unit is a blaupunkt san diego dj and the other (same base units ) are milano rcr127 and avignon rcm ??
cam.in.head
so if my understanding of your description is correct .the front facia button sends a signal to a microprosessor then this sends a signal to the main board regulator to turn on .
so i have confirmed standby power is present at the facia socket (5v) and im pretty sure this uP is in thd defacheable facia panel .so i know 100% this uP is ok .when the unit next fails to turn on il  heck that standby power is there and if it isnt thats the best fix .if it is then i know its something internal .it could fault tommorow or next month ! .
LC0112G
Is it one of these? https://elektrotanya.com/blaupunkt_san_diego_dj31_sch.pdf/download.html
If it is you can download the circuit diagrams from the link on that page.
It looks like the processor on the faceplate (Page 24) is only used to interface the various front panel keys. Communication with the main board is over an SPI (Serial Peripheral Interface) using 4 pins - MISO, MOSI, SCK and CE. However the on/off function has it's own pin - Pin 8.
It looks like on the main board pin 8 comes in on page 19, but goes straight off again to the power supply page. I think that's page 8, and comes in on the bottom left corner. Couple of transistors there (V2054 and V2051), and what looks like a thermistor (R2051). That's where I'd start poking about.
