Author Topic: Rear air shocks  (Read 7897 times)
annihilator
  • Wirral
    • Omega Tourer V6
Rear air shocks
« on: 06 March 2026, 16:06:38 »
Not an omega but a Carlton estate with rear air suspension
The nsr shock is fully extended and is rock solid stuck in this position. Have removed it and it will not budge is it knackered?
  • Online Online
Re: Rear air shocks
« Reply #1 on: 06 March 2026, 17:06:33 »
Yup ;( . The fluid part has failed internally.
The air bladder doesn't have a valve in it... The pressure is regulated by a relief valve on the pump.
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
Re: Rear air shocks
« Reply #2 on: 06 March 2026, 17:31:38 »
this certainly sounds internal .never seen this before .
also if if is internal then the air bladder should be soft and squashy .if its rock hard then its the air inlet that is blocked .very unlikely i know but easy enough to see .
annihilator
  • Wirral
    • Omega Tourer V6
Re: Rear air shocks
« Reply #3 on: 06 March 2026, 17:52:56 »
Thanks for the info. standard shocks incoming  :)
    • Grandland 1.5 diesel
Re: Rear air shocks
« Reply #4 on: 06 March 2026, 18:29:43 »
Put it in a vice, connect a compressed air line, and see how far you can shoot the piston.
Diesel till I die
Re: Rear air shocks
« Reply #5 on: 06 March 2026, 19:46:06 »
Didn't the rear air suspension on a Carlton estate just have a schrader valve in the boot area of the car  :-\
  • Online Online
Re: Rear air shocks
« Reply #6 on: 06 March 2026, 19:56:15 »
Perhaps, presumed it's the same set up as the Omega :-\
That said, if it's off the car, the Schrader valve won't be holding much air in the system ;D
  • Online Online
Re: Rear air shocks
« Reply #7 on: 06 March 2026, 19:57:40 »
With new, suitable, springs ;)
Re: Rear air shocks
« Reply #8 on: 06 March 2026, 19:59:34 »
good point!  ;D ;D
cam.in.head
  • West yorkshire
Re: Rear air shocks
« Reply #9 on: 06 March 2026, 22:46:24 »
yes similar idea to the omega .springs are softer but finding std springs shouldnt be an issue
annihilator
  • Wirral
    • Omega Tourer V6
Re: Rear air shocks
« Reply #10 on: 07 March 2026, 16:12:31 »
Diamond estate had auto levelling like omega,Cdx etc was manual.
cam.in.head
  • West yorkshire
Re: Rear air shocks
« Reply #11 on: 07 March 2026, 21:59:21 »
carlton mk2(83-86) has manual inflation valve ito pump up as req .my cd has this but i fitted a guage as well to see what its at .
annihilator
  • Wirral
    • Omega Tourer V6
Re: Rear air shocks
« Reply #12 on: 08 March 2026, 11:25:53 »
Mines a mk3 diamond 24v  :)
