Multi Info Display to Colour Info display
Started by Clarkey, 03 April 2026, 15:35:30
Clarkey
As the heading suggests I want to upgrade Info Display on my 01 Omega to the colour info display. The current head unit is Philips CCR2006 with BOSE. What do I need to change to get the colour info display to function properly? Hoping someone has done this to a facelift Omega in the past and can give guidance.
Thanks in advance,
James.
Think there's some sort of guide... :-\
Otherwise it's simply a question of reading a wiring diagram and some time and patience.
For the full CID experience you're going to need an NCDC head unit but be mindful the unit from the Vectra C is of zero use to you
Check if you have the RGB cable strapped behind the display.  If you have, and yours is an Elite, then from memory, it's a near straight swap with just a link wire needed.  If you haven't, the RGB cable needs adding, which means studying the wiring diagram.
(RGB cable only needed for Nav Map view)
As DG says, the display will only work when paired with a NCDC 2000 series or NCDR 1000 series.  The 2 have to be paired together via a Tech2 or similar.  If using donor parts, they either have to be in a depaired state then paired together, or come from the same donor (ie, already paired).  It is not possible to depair any of the paired components unless they are all present when attempting to depair.  The pairing code entered when paired is also needed.
If you attempt to use the CID alongside the CCR2006, it will "work" (ish) but pop up a security message every few seconds.
A correction to what DG says, *any* NCDC 2000 series will work, even from a Vectra-C/Signum, but the CID MUST be from an Omega or Astra-G
The Vectra unit has a different plug set  ;)
Quote from: Doctor Gollum on 03 April 2026, 17:31:56
The NCDC unit is identical.  It was only fitted for about 2-3 years when the Vec-C got a minor facelift and the "double digit" range of headhunts (with the CD70 being the replacement for the NCDC on the posher Vectras.
Quote from: TheBoy on 03 April 2026, 18:26:22
The difference, iirc,  boils down to the CanBus that the Vectra C used that the Omega didn't have, hence the differences in the wiring.
Quote from: Doctor Gollum on 03 April 2026, 18:39:46
Which is what causes the (almost identical looking) CID to be different hardware.  The NCDC/NCDR series all have a CAN bus :y
Clarkey
Thanks for replies chaps. Was hoping I could use original radio. Should have done my homework before acquiring colour info display on its own. My machine is Executive model. 1 below Elite. No RGB cable present. Does RGB cable run from back of stereo to display? Have the option of stereo and loom from car display taken from. Just need to know what section of loom to ask for. Must also double check donor car was bose equipped.
that bit of loom isn't easy yo remove and refit. Best to inspect wiring diagrams, and adjust loom as required.
Clarkey
Quote from: TheBoy on 04 April 2026, 16:32:32
Decision has been made for me. Head unit has already been sold separately. No option but to return display.
Just gonna keep standard. Should have looked before I leapt. Lesson learned.
Quote from: Clarkey on 07 April 2026, 14:21:00
I suspect that seller will be getting the HU back as well, as it probably hasn't been depaired, so not a lot of use to anyone.
Migv6 le Frog Fan
Mmm. I recently bought an NCDC2013 without a display screen in case I need spares for mine. I believe it came from a Vectra.
I wonder if it was from the same seller.  ;D
Quote from: Migv6 le Frog Fan on 07 April 2026, 16:17:51
You're a sod ;D
The coding is on the front board in the top unit.  So you can use for spares, as long as it's not that board that fails.  Additionally, the CD unit coding is on the vertical board in the (lower unit) CD part.
Migv6 le Frog Fan
Cheers. Will hopefully remember to look this up again should I need to.  :y
