Wanted - UK front left hand door harness / loom 9146837
Started by johnnydog, 24 June 2026, 18:35:22
johnnydog
As the title, anyone got a good UK spec front passenger door harness /loom, GM part no. 9146837 ident A2J. Fitted to later Elite models apparantly from Y1000001 with electric memory seats according to EPC.
Mine has suffered from corrosion to the pins etc in the big connector block..
Please?
Thanks
cam.in.head
theres a brand new lh front door harness on ebay now .if its differebt maybee you can add the extra pins ???
cam.in.head
johnnydog
Quote from: cam.in.head on 30 June 2026, 09:30:13
Thanks - that's the chap local to me who gave me the new loom albeit for an earlier (1994 on) car which is quite different.
I've managed to find a loom of the correct ident no / part no from another seller - it's from a scrapper, and I'm just waiting for some photos of the condition of the large block connector as water ingress causing pin corrosion  seems to be quite common.
As an alternative, I may be able to salvage some of the pins from the one I acquired to repair my existing one.
Dispite suggestions of all looms being basically the same, one from a 2000 FL Elite I found for example, was noticeably different, both in the pins in the door connector, and the pins in the electric mirror plug....
I'm holding out for a good one of the same ident no, or repairing my own, if only to ensure all will work as originally intended.
johnnydog
I've now established there are minor differences in the smaller pins in the early model connector so that's a non starter.
Apparantly the RH door harness from a LHD Opel Omega is also suitable - as long as it has the ident A2J, p/n 09146837.
There are a couple of passenger harnesses on Ebay, but not the correct ones with quite a difference in the pin layout / orientation.
Unless I risk one on a website in Belarus......
johnnydog
After a trip via Birmingham, I now have a LH front door wiring harness of the correct ident no. and part no.  (I was passing so not the sole purpose of the journey).
Definitely in better condition than the one that was on my car, so fingers x'd :y
Some paint repair needed around the holes for the 'winged' clips that secure the inner door seal to the door bottom before fitting.
Many thanks to 'tango' on here for the harness. A very pleasant and helpful bloke :y :y
