Author Topic: Brake fault  (Read 114194 times)
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: Brake fault
« Reply #45 on: 05 July 2026, 15:24:31 »
Massive, massive thanks to YZ250 for popping over - he's not exactly just around the corner - and for his perseverance on it :y
I hope you don't hurt like I do, it's not a comfortable position to access it the way you did, laying with your back on the cill for ages.
No worries, happy to help.  :y  I think we always knew that the refitting would be challenging working blind, but I thought that we were on a hiding to nothing at one stage when the time kept ticking by.  ;D
All good here thanks, hopefully I’ll still feel the same in the morning.  ;D  I’d have never asked you to double check what I’d done if I’d have known your back was so bad, you looked in agony.  :-[
Re: Brake fault
« Reply #46 on: 05 July 2026, 15:37:16 »
Job bleddy well jobbed :y
Re: Brake fault
« Reply #47 on: 05 July 2026, 19:04:57 »
Oh....and Jaime, and Mrs Jaime, you are effing useless  ;D
I'd like to say we loosened it up for him.  Obviously that's BS, but it sounds good ;D
Re: Brake fault
« Reply #48 on: 05 July 2026, 19:05:41 »
My Smart Roadster had a brake/ESP/ABS problem that turned out to be broken wire to/from the brake switch. Swapping the switch was fairly simple ..... however repairing the wire involved lying on the seat arse about face so I could reach the loom above the switch. That was really fun!  ;D ;D
Re: Brake fault
« Reply #49 on: 05 July 2026, 19:09:44 »
I'm not in a good way, lol.  I'm just about to jump in a (hot - don't tell my physio) bath.  If you never hear from me again, I couldn't get back out ;D
I was annoyed I was unable to check it, as I'd felt a bit useless all that time, as its one of those jobs where an extra pair of hands doesn't fit, let alone help.  So the one job I had, and I still couldn't do it!
Fingers crossed you wake up without any aches and pains from it, and thanks again.  Mrs TB was just saying you "are a superstar"
YZ250
Re: Brake fault
« Reply #50 on: 05 July 2026, 19:33:42 »
 as it’s one of those jobs where an extra pair of hands doesn't fit, let alone help.
Yep, definitely a one man job.  :y
I had a thought on my drive home. When we do the next one,  ;D ;D we could tie a piece of string around the plunger in a slip knot, and then poke the string through the hole and pull the switch plunger through the hole.  :y  Also, if the accelerator pedal was removed we wouldn’t have kept getting our arm trapped between that and the brake pedal.  ;D
All good fun.  :y  I’m just glad that you knew what position the switch plunger should be in, as I wouldn’t have known that.  :y
Viral_Jim
  • Telford
    • Too many, mostly broken
Re: Brake fault
« Reply #51 on: 06 July 2026, 09:38:49 »
The last time I had to do a brake switch - on the Terracan iirc I ended up sitting upside down in the seat with feet braced on the headlining and my head and shoulders in the footwell.
I believe my ex wife has the pictures - which is a bit of a worry now I come to think about it.  :-\ ;D
Well done to all involved - job jobbed!
Pages: 1 2 3 [4]  All   Go Up
