Author Topic: Hose  (Read 11644 times)
Steveh
  • Debyshire UK
    • Omega 2L 16V
Hose
« on: 14 August 2026, 17:15:00 »
Hi does anyone know where I could get a coolant hose for 2 L 16v one at the back of the head goes to diverter valve part number GM 90 466 235 ? I've drawn a blank so far its got sharp bends so i dont think silicon would work got a random bit of pipe in there at the moment but its kinked so not ideal
Steveh
  • Debyshire UK
    • Omega 2L 16V
Re: Hose
« Reply #1 on: 14 August 2026, 17:55:28 »
Been looking at methods of forming bends in hose with plumbing bending spring and boiling water , heat shrink, sand and oven has anyone tried ? what's best ?
Re: Hose
« Reply #2 on: 14 August 2026, 19:40:22 »
Nothing available either from dealer, or from a breaker?
Steveh
  • Debyshire UK
    • Omega 2L 16V
Re: Hose
« Reply #3 on: 14 August 2026, 19:45:59 »
I've not found anything online after several hrs searching even with A.I. help lol ordered a length of 19mm pipe off ebay I will have a go forming the bends watched a few tutorials on youtube seems easy enough got the old one as a pattern
Steveh
  • Debyshire UK
    • Omega 2L 16V
Re: Hose
« Reply #4 on: 14 August 2026, 20:04:02 »
Its in a goddam awkward spot behind the engine cut my arm to shreds reaching in  :)
Re: Hose
« Reply #5 on: 15 August 2026, 11:10:54 »
Doubt AI would help locating one - you probably need to look for an ad of somebody breaking one, and then contacting them to see if they have the part.
Good luck with making your own, interested to see how you get on :y
Steveh
  • Debyshire UK
    • Omega 2L 16V
Re: Hose
« Reply #6 on: 20 August 2026, 02:24:10 »
Had some success experimenting making up a hose used 15mm plumbing bending spring wrapped in foil as it was a bit small a mastic gun as a clamp and heating the rubber with a heat gun then cool in ice water not fitted it yet but I think its close enough  :y
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
Re: Hose
« Reply #7 on: 20 August 2026, 09:57:12 »
Seen quite a few posts on Facebook Omega owners recently breaking, all parts. And some bloke called Gavin Mcleer gets mentioned as having all parts :y
Re: Hose
« Reply #8 on: 20 August 2026, 11:25:39 »
My only concern is if it's brittle.it won't take much to crack, especially with the heat cycles.
Fair play for trying it though :y
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
Re: Hose
« Reply #9 on: 20 August 2026, 12:02:39 »
can you find a picture of the actual pipe online anywhere to see what it looks like .i have a box of many many hoses from various cars
Steveh
  • Debyshire UK
    • Omega 2L 16V
Re: Hose
« Reply #10 on: 24 August 2026, 20:48:04 »
Cheers everyone my homemade hose now fitted all good no kinks I also fitted new diverter valve I've had for ages while I was in there ( I thought that's what was leaking originally a few years ago but it was the hose split I cut a a bit off the hose back then)
Steveh
  • Debyshire UK
    • Omega 2L 16V
Re: Hose
« Reply #11 on: 24 August 2026, 21:39:52 »
