Heated seats blow the fuse
Started by Valentin, 02 November 2026, 11:18:21
Valentin
Hello everyone,
With low temperatures coming back, heated seats are once again a great feature while long journeys. But I face a curious issue since last winter. If for example I switch ON the driver side seat and let it regulate after something like 15/20 minutes, the 30A fuse blows and thus no more climate control AND servotronic steering  :-\ because it seems it's on the same circuit.
It's the 3rd fuse I change since last winter and I want to know what's going on. This is a prefacelift with only ON/OFF selection.
- Does it imply a timer to prevent any overheat ? If yes, is there a relay that can be stuck and overpass the defined time ?
- Is the resistant film in the seat prone to short-circuit when very hot ?
- How can I mesure the impact of heated seats on the electrical system while driving and turning the steering wheel ? :D
Thanks a lot guys :y
Does anybody already had the same issue ?
So PFL/MFL simply apply power to the the element in the seat.  FL have a controller unit embedded in the seat.
So implication is you have an element that is causing an issue, although its odd to only do so after that amount of time.
