Author Topic: sod it  (Read 1035 times)
Martin_1962
sod it
« on: 27 September 2008, 16:45:22 »
Been working on hte car this afternoon  - thought it would be an easy oil change.
Apart from having the wrong socket ratchet and forgetting to go under with the filter it was.
But
1) Big oil leak - cam cover seals :( :'(
2) Back suspension is down and soft, springs? shocks?
3) My back is agony after leaning over the engine for 20 minutes.
4) Rear tyres shot :(
HAving a mug of tea then out to do the pollen filter another big job as the scuttle is a bit blocked (cleaned this time last year) and I have to shift the ECU ::)
Dusty
  • Shropshire
  • Erotic Romance Author
Re: sod it
« Reply #1 on: 27 September 2008, 18:38:36 »
But it is lottery night tonight Martin and if you just get those six little numbers...............your luck could change. :-* :-* :-* :-*
Martin_1962
Re: sod it
« Reply #2 on: 27 September 2008, 20:14:18 »
I suppose I could employ James for a couple of days - I'll do the back and he can do the front ;D ;D
I was fine when I was under - leaning over is agony :-[
Re: sod it
« Reply #3 on: 27 September 2008, 20:20:05 »
last nights would have been nice.
No Jackpot winner.
Match 5 and 2 Stars         0        £0.00
Match 5 and 1 Star       15       £7,055,142.10
Martin_1962
Re: sod it
« Reply #4 on: 27 September 2008, 20:43:45 »
Scuttle was blocked - by sand - a little oik chucked sand over my car on holiday and I had washed it off into the scuttle.
Vacuumed it out then VAXed the area and water went through fine, the old pollen filter was disgusting.
My part list is getting big!! :(
STMO123
Re: sod it
« Reply #5 on: 27 September 2008, 20:47:35 »
But
That's a worry. Dont you check them regularly?
Martin_1962
Re: sod it
« Reply #6 on: 27 September 2008, 20:53:20 »
But
THey are pumped up and the edges are OK, I reckon only a few hundred left until illegal
