Author Topic: Plumbing  (Read 996 times)
Martin_1962
Plumbing
« on: 05 October 2008, 20:46:14 »
Fitted new taps in the downstairs loo today, spent more on tools than it would have cost to get a plumber.
Took 2 hours and a few minor leaks.
All OK now.
Fitted isolation valves as well - good job too!
STMO123
Re: Plumbing
« Reply #1 on: 05 October 2008, 20:51:13 »
All OK now.
Did you use compression or capilliary fittings?
Martin_1962
Re: Plumbing
« Reply #2 on: 05 October 2008, 20:53:33 »
compression for the two isolation valves and the new tap adaptors were soldered
STMO123
Re: Plumbing
« Reply #3 on: 05 October 2008, 20:58:11 »
I dont trust soldered joints. I'm not good enough to always get them right first time and their a bugger once there's water in there.
Re: Plumbing
« Reply #4 on: 05 October 2008, 21:09:59 »
Have more faith in yourself; practice makes perfect and you can do it like anyone else! :y :y
Just always ensure you have cleaned the end of the pipe with wire wool, removed any schaff, smeared a thin layer of flux around both the end of the pipe and pre-soldered joint and heat up all round.  Bingo once that lovely ring of silver appears around the edge of the joint! :D :D :y :y :y
Martin_1962
Re: Plumbing
« Reply #5 on: 05 October 2008, 21:11:10 »
Mine are fine looked in the pipe and shiney silver around the other end of the join.
That is one thing I can do - solder!
Re: Plumbing
« Reply #6 on: 05 October 2008, 21:12:04 »
Wire wool!
Green scouring pads.....and we seem to have an endless supply under the sink which is handy!  :y
miggy
Re: Plumbing
« Reply #7 on: 05 October 2008, 21:12:24 »
True
Re: Plumbing
« Reply #8 on: 05 October 2008, 21:23:10 »
Wire wool!
No wire wool as it scores the copper as well as cleaning it and gives a perfect surface for soldering.  Used by me since a master plumber taught me when I was 20, and often mentioned in all good plumbing manuals. :D ;)
Never had a joint failure! :y :y
« Last Edit: 05 October 2008, 21:23:48 by Lizzie_Zoom »
miggy
Re: Plumbing
« Reply #9 on: 05 October 2008, 21:33:00 »
Wire wool!
Wait till you get into your seventies Lizzie..... ;D ;D ;D ;D
« Last Edit: 05 October 2008, 21:33:54 by miggy »
Re: Plumbing
« Reply #10 on: 05 October 2008, 21:34:37 »
Wire wool!
Very good Miggy  ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D :y
