Author Topic: Boot Protectors  (Read 6910 times)
nixoro
  • Hitchin, Herts
Re: Boot Protectors
« Reply #15 on: 04 December 2006, 12:26:22 »
Anyone tried one for the saloon, my car is missing its carpet at the moment as I had a nasty spillage in the back had it hung over the washing line for a little bit to dry out.
    • E250 Est / Elroq
Re: Boot Protectors
« Reply #16 on: 04 December 2006, 12:38:42 »
Got the cannon in the wife's saloon.
Read into the fact I am looking at a different solution for mine what you like ;)
It's Ok at best, does the job, but could fit better
The Barge Captain
Re: Boot Protectors
« Reply #17 on: 04 December 2006, 14:12:56 »
Isn't that a bit heavy and difficult to aim? ;D
The Barge Captain
Re: Boot Protectors
« Reply #18 on: 04 December 2006, 14:15:21 »
I've just got a large piece of cardboard cut to shape.  Free with every lcd telly purchased  ;D
    • E250 Est / Elroq
Re: Boot Protectors
« Reply #19 on: 14 December 2006, 21:18:54 »
Boot liner arrived after 10 days.
Quite a good fit, except it is not designed for an omega with a factory fit autochanger, so slight modification (Stanley Knife) required.
Not quite as 'heavy duty' as I hoped, but it's OK.
The lip all around may be an issue if the seats are down for a large load, probably better in the saloon.
The edges are quite 'shiny' so slippy, the centre is a sort of non slip mat effort.
Will try and get out with the camera at the weekend.
Matchless
  • Nottingham
    • A white van
Re: Boot Protectors
« Reply #20 on: 15 December 2006, 10:11:14 »
Hi Guys
I decided to go for the Cannon rubber one from hal***ds. Comes in a box marked type 2. It fits almost perfect in the estate, length almost spot on, about 20 mm to wide, it does come up a bit short on one side were the wheel arch is smaller on one side leaves a gap about 100mm square. but other than that fine. :y
Sounds like they are shaped to miss the CD changer which hides in an extension to the drivers-side wheel arch
Gwilym
  • Bridgwater, Somerset, UK
Re: Boot Protectors
« Reply #21 on: 16 December 2006, 16:06:26 »
On balance though, are you recomending it?
White '00 3.0 MV6 Estate (Ex Met Police Firearms Car)
    • E250 Est / Elroq
Re: Boot Protectors
« Reply #22 on: 16 December 2006, 17:49:01 »
Yeah, I would buy it again.
Gwilym
Re: Boot Protectors
« Reply #23 on: 16 December 2006, 19:34:20 »
I'll place my order then
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Boot Protectors
« Reply #24 on: 17 December 2006, 07:37:34 »
...but you've already got one..... ;D
I like red cars
