Author Topic: Re: Fuel trim and Cat Efficiency codes explained  (Read 864 times)
« on: 14 October 2008, 11:44:39 »
Excellent write up Kevin  :y :y :y :y
Thank you
 Very, Very, minor point .. on the 3.2 OBDII the cat effieciency fault codes are 0420 & 0430  -- your 0340,0440 are totally different errors ..
Just don't want OBDII folks to get the wrong idea, write up still immensley valid  :y :y :y
http://www.obd-codes.com/trouble_codes/
« Last Edit: 14 October 2008, 11:45:37 by entwood »
« Reply #1 on: 14 October 2008, 11:49:58 »
Thanks, Entwood. Codes corrected. Don't know why I keep getting those confused. I clear the damned things out of my car often enough. ;D
« Reply #2 on: 14 October 2008, 12:08:00 »
Kevin Wood Classic..Excellent :y
Admins, I think the write up deserve a place in Technical info section
and will be good reference to check everytime.. ::)
« Last Edit: 14 October 2008, 12:11:26 by cem_devecioglu »
« Reply #3 on: 14 October 2008, 19:27:57 »
Moved to Tech info, thanks Kevin Wood :y
