Author Topic: Odd computer problem ..  (Read 1521 times)
« on: 16 October 2008, 22:28:31 »
I have an image file in mdf/mds format that on this system, opens in Daemon tools perfectly, works without any hiccups.
When I transfer it to the laptop, it mounts ok and is visible as a virtual drive, when I  try and open it there, the initial file opens ok .. then I get a message "can't find DVD ROM"
Both computers are XP SP3, both are running the latest Daemon tools, I've copied the files across in 3 different ways .. so its not a corrupt file problem.
I've also tried a programme called MagicDisc ... same result .. works on this system .. fails on laptop .. :(
Anyone any ideas ???
« Last Edit: 16 October 2008, 22:30:28 by entwood »
rickyboy
  • Glasgow
Re: Odd computer problem ..
« Reply #1 on: 16 October 2008, 22:37:59 »
Obvious one but is the DVD drive working ok on the laptop?  Check that its reading DVD's ok and also check the device manager.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #2 on: 16 October 2008, 22:49:00 »
Just a thought, copy the file(S) to your laptops hard drive, then open from your programs file menu rather than the Disk.
Bandit127
« Reply #3 on: 16 October 2008, 22:55:26 »
Try extracting the mdf/mds file on the original system to a regular ISO. ISO is universal and won't rely on a mounted virtual (or real) drive.
If not, UltraISO might help (for the laptop)
http://www.freedownloadscenter.com/Utilities/Backup_and_Copy_Utilities/UltraISO.html
Also, Alcohol 120% seems to be the native software for mdf/mds files.
http://www.download.com/Alcohol-120-/3000-2646_4-10158124.html
« Reply #4 on: 16 October 2008, 23:03:48 »
Thanks for the ideas .. the nature of the programme is such that it has to be run from a vitrtual disk , can't be "split" using an ISO programme.
What is doing my head in is that it works on one system but not the other .. :(
Downloading alchohol120 to try that now ..  :y :y
Edit : same on alchohol .. :( ...
edit 2 :  Just noticed a very small thing ... when mounted on this system .. if you go to "my computor" .. the virtual drive is still "DVD Drive (I:)" and it works, ... on the laptop as soon as you mount the image the drive changes to "ACFGDE46 (I:)" and it won't work ... I wonder why the difference ???
« Last Edit: 16 October 2008, 23:25:51 by entwood »
Bandit127
« Reply #5 on: 16 October 2008, 23:27:00 »
Presume then that Daemon Tools etc are able to mount a virtual drive on the laptop with the same drive letter as it was compiled/compressed with?
That was what I think I was getting at with the ISO suggestion..?
« Reply #6 on: 16 October 2008, 23:57:55 »
Tried different drive letters, presently set up as identical .. :(
most weird .. but off to bed now .. it can wait 'til tomorrow ... :(
Plomien
  • Swansea
    • Landrover Freelander TD4
« Reply #7 on: 17 October 2008, 08:51:33 »
try power ISO never failed at opening stuff with that
« Reply #8 on: 17 October 2008, 09:02:54 »
I have had some grief with daemon tools,
but only with a specific version of a program that used to install easily.
What prog are you trying?  And is this the free version of daemon tools or the professional version.
PM if you would rather ;)
« Reply #9 on: 17 October 2008, 09:08:01 »
PM sent .. :)
