Author Topic: Fridge very frosted up  (Read 2030 times)
waspy
« on: 24 October 2008, 11:27:27 »
Does anyone know why my fridge gets really frosted up at the back? it never used to, it's started doing it as off late. Would a small hole some were that's allowing air to get in the compartment do this, say maybe around the door seal?
Give it two weeks & i've got enough ice to fill up a battery with de-ionized water
Timbuk
  • Telford
  • owned a Datsun 120y once!
Re: Fridge very frosted up
« Reply #1 on: 24 October 2008, 11:45:50 »
If you have a drain hole at the back it may be blocked
« Reply #2 on: 24 October 2008, 11:55:20 »
My freezer is like that, but the freezer itself.   I accidenly left the door open about half an inch, and the hole freezer compartment is now like the Antartic, completely frozen solid. :-/
Debs.
« Reply #3 on: 24 October 2008, 12:08:54 »
 :o Eeeeeeeeeeew! :o
 ;D ;D ;D ;D
Andyb
  • Lincoln
« Reply #4 on: 24 October 2008, 12:17:49 »
 :o Eeeeeeeeeeew! :o
i dont want to even go there  :-X
 ;D ;D ;D ;D
waspy
« Reply #5 on: 24 October 2008, 12:41:18 »
No, i gave the hole a good poke  :D when it first started doing it.
Thanx for the suggestion :y
Ian_D
  • York
« Reply #6 on: 24 October 2008, 12:44:59 »
 :o Eeeeeeeeeeew! :o
 ;D ;D ;D ;D
;D pmsl!  :y
[size=12]
« Reply #7 on: 24 October 2008, 12:57:05 »
 :o Eeeeeeeeeeew! :o
 ;D ;D ;D ;D
Trust you Debs!
 ;D  ;D  ;D  ;D  ;D   ;D  ;D  ;D  ;D
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #8 on: 24 October 2008, 13:11:41 »
is it a frost free freezer? if it is and its freezing up then one of the fans has expired! simple to fix!
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
« Reply #9 on: 24 October 2008, 13:44:33 »
Sounds like it needs defrosting. Just switch it off for around 8 hours or until all frost and ice has gone, give it a good clean and switch it back on.
Set the temp setting to maximum for the first 12 hours then back to your normal setting. Should sort it out. :y
« Last Edit: 24 October 2008, 13:44:51 by bob.dent »
waspy
« Reply #10 on: 24 October 2008, 13:48:52 »
tmx & Bob It's. not a frost free & i've already defrosted, cleaned & dried it out. I'm outa ideas :-?
Thank you for your suggestions :y
jaykay
  • Fareham Hampshire
« Reply #11 on: 24 October 2008, 14:30:38 »
Your freezer is pulling in ambient air from somewhere.....could be door seal or perhaps where the pipework  enters through the insulation......and that warm air has moisture. this then freezes.
Stop the ambient air from entering and your problem is solved.
Hope this helps
Richie London
  • heathrow
« Reply #12 on: 24 October 2008, 14:44:01 »
  snap, always doing it :-[ :-[ :-[
waspy
« Reply #13 on: 24 October 2008, 15:47:51 »
Hope this helps
Thank you also :y This is what i thought, though under first investigation there's nothing. I'll have another look see :y
sir moanalot
  • fens
« Reply #14 on: 24 October 2008, 16:28:34 »
ah at last a question i can answer!
1) door seal maybe faulty or door dropped allowing air in from the top.
2) the thermostat has gone faulty and is running the fridge permanently. (compressor will be red hot at the back of the fridge)
3) the insulation at the back or sides may have deformed and cracked  allowing warm air spots (you usually hear cracking or banging sounds).
4) you may have a system (gas) blockage in the evaporator which will leave a cold spot at the back -building up with ice/frost.
 faults will be in that order of common breakdowns.
tone :y
