Author Topic: washing machine furbared  (Read 3372 times)
« on: 23 October 2008, 18:49:34 »
Its an LG, with the motor built onto the back of the drum.No seperate motor or drive belt.
I have stripped all the bits of the back of the machine and found that the bearing which supports the rear of the drum has collapsed.this explains why it was "walking" across the kitchen floor on tuesday night. Anyway the problem is ,I cant see how the bearing should be removed,just wondered if anyone had any experience of these contraptions.? :-/ :'(
I have driven to London today ,and have to go back later tonight,Mrs Bitz would like the wachine working before I go. ::) ::)
« Last Edit: 23 October 2008, 18:51:01 by albitz »
Re: washing machine furbared
« Reply #1 on: 23 October 2008, 18:51:43 »
traditionally here we choose somebody to sit on the machine on these occasions ;D :y
« Reply #2 on: 23 October 2008, 18:51:56 »
Dunno about LG - did an Indesit a few years ago - holding bolt had a left hand thread - once that was off bearing & assembly came out as a unit and new unit straight back in. :)
« Reply #3 on: 23 October 2008, 18:52:29 »
Some you can withdraw them on a carrier in the back of the outer drum.
On our ruddy Zanussi I had to split the two halves of the outer drum, which meant stripping the machine right down.  >:(
« Reply #4 on: 23 October 2008, 18:53:31 »
I was out of the house for a few hours ,so that may have already been tried. ;) ;D ;D
The bolt in front of the bearing came of quite easily,just cant see how to pull the bearing out. I wouldnt be surprised if it is similar to yours Kevin,in that it has to be completely dismantled to get at it. I dont mind that much if it does,I would just like to know how to proceed rather than faf around for hours getting nowhere fast.
I do have the haynes book of washing machine lies and guess what , its rather useless,doesnt even mention that type of design. ::)
« Last Edit: 23 October 2008, 18:58:10 by albitz »
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #5 on: 23 October 2008, 18:58:09 »
my whirlpool badge engineered Ariston died on sunday Shocks have gone which in turn has destroyed the motors ECU
be warned my washing machine has a LIVE Motor ie the motor chassis is Live its supported with rubber bushings because myn had this i gave up and have bought a Bosch Classixx 6 should last a long time i was told!
« Reply #6 on: 23 October 2008, 19:06:08 »
 ;D
Photos might be useful. :y On mine, the spindle just came straight through a tubular metal section which was moulded into the plastic outer drum. You could see the outer bearing pressed into this once the sprocket was removed, but it was clear that the drum had to be split, and the inner drum withdrawn to get the bearings out. As it turned out, the inner bearing was larger, so there would have been no other way.
« Reply #7 on: 23 October 2008, 19:07:28 »
Our house eats washing machines  >:(
So last time got a very good deal on a Miele, with a 10 year guarantee!
must be 2 yo now, and hasnt missed a beat :)  (tocuh wood)
on the other had I've just had to order a new toploader! to replace a 50 year old broken one, cant whinge at that!
« Reply #8 on: 23 October 2008, 19:08:53 »
In those days the last thing I want to hear is a fubar washing machine  :(
Winter is approaching and I dont want to hear any extra expense :-/
Richie London
  • heathrow
« Reply #9 on: 23 October 2008, 19:09:20 »
very expensive to repair so im told
« Reply #10 on: 23 October 2008, 19:10:27 »
Just buy her a new washing machine Albitz as a lovely treat........and NOT as a Christmas present! ::) ::) ::) ::) :D ;)
« Reply #11 on: 23 October 2008, 19:11:53 »
Course not!
Washing machines far too expensive for Christmas prezzies.
Iron's on the other side are about the right price, and make excellent presents I'm told  ;D
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #12 on: 23 October 2008, 19:15:45 »
miele are the best you can get! the new ones have 20yr guarentee's v expensive though £799 is alot of money
« Reply #13 on: 23 October 2008, 19:20:09 »
I recently bought another washing machine because bone idleness prevented me from looking inside the old one when the drum wouldn't turn. As I was removing it, ready for the new machines arrival, I immediately saw the reason why the old machine's drum wouldn't turn. A small bearing on the end of the motor had completely collapsed. :-[ A new bearing [size=8]from work[/size] sorted it.  :y :y
serek
  • huntingdon
    • 3.2 mv6
« Reply #14 on: 23 October 2008, 19:21:31 »
Miele is expensive but very good and work easy 10-15 years
