Author Topic: LED rear light caused headache  (Read 3075 times)
Re: LED rear light caused headache
« Reply #15 on: 10 November 2008, 14:04:45 »
If I shook my head it was very obvious. was basically a couple of columns and appeared like this.
Not viewing angle, but driving frequency.
They should be driven so that there are some lit all of the time.
Thats likely to be more down to some sort of defraction grating in the lense setup.
Certainly jack all to do with the switching frequence.....if thats above 30Hz you wont notice it.....at 100Hz plus its certainly not the issue.
No it was the swith frequency imagine that each dot was a diode and normally two columns, move your head and you got the extra columns as they pulsed on and off
Again, sounds more like a grating.....if it was switching frequency then it would have nothing to do with the position of your head  :y
Martin_1962
« Reply #16 on: 10 November 2008, 15:03:28 »
Moving eyes rapidly - good way of finding flickering lights
« Reply #17 on: 10 November 2008, 15:04:46 »
Put it this way......do you notice flourescent lights flickering and incandescent lamps flickering?
Martin_1962
« Reply #18 on: 10 November 2008, 15:07:28 »
Fluorescent only when nearly worn out (one near me right now) and never with a filament bulb.
But does the fluorescent coating have latency so it never goes dark?
« Reply #19 on: 10 November 2008, 15:12:03 »
It has a level of latency but, the graph is a log setup so the high brightness decays very fast leaving a background lvel of light over the period of a minute......and hence why Plasma and CRT Tv's can not display true black.
Bottom line is, the effect still sound more like that of some sort of grating (which is often used in such lenses to difract the light) resulting in many bright and dark spots.
I cant beleave they use a switching frequency as low os 30 Hz.....1Khz minimum I would of thought these days.
« Last Edit: 10 November 2008, 15:12:35 by Mark »
« Reply #20 on: 10 November 2008, 15:14:29 »
They have quite short "off" times in comparison, though. An incandescent bulb has a filament that filters out the mains frequency by virtue of the fact that it has heat capacity and both types will conduct on both halves of the 50Hz cycle.
As it happens I have a 'kin bright LED cluster on the bench at the moment that is destined for the rollbar of my Westfield so I might have a little experiment and see if I can reproduce the issue, because these lights get to me too. I'm sure it's some sort of multiplexing / PWM issue, although I can't understand why they'd be switched so slow.
SheWhoMustNotBeOUTBID
  • Drives the only front wheel drive miggy
« Reply #21 on: 10 November 2008, 15:24:42 »
[smiley=undecided.gif] I started reading this thread thinking that you had one on your Omega & it was that one that was causing you a headache!  :-[
I would have thought it would be the HID headlamps from Jags, BMWs & Mercedes that would have caused a headache.
How long was spent behind this uber bright rear Led brake light?
Never look into the light.....  [smiley=laugh.gif]
No.., contrary to advice offered at the beginning of the thread.., don't close your eyes as u may find yourself GOING 'into the light' very shortly afterwards :P
Save The Earth.., its the only planet with chocolate!!!!!!!!!!!!!!!
I wish admins were clever enough to remember to let me on the forum cause I do good coffee in return!
« Reply #22 on: 10 November 2008, 15:30:00 »
Again, you would be surprised how much the temp of the filament changes as the cycle moves and hence the light does indeed flicker.
« Reply #23 on: 10 November 2008, 15:37:29 »
As a way to observe this, put a diode in series and chop out half the cycle.....this makes it very obvious.
The only reason I can think they are using any sort of switching on an LED light is to maintain a constant brightness at varying supply voltages....and every LED driver IC I have seen in past years has had swicthing frequences of 20Khz upto 2M
Martin_1962
« Reply #24 on: 10 November 2008, 16:06:33 »
I think it may have been faulty - don't often notice issues like this.
Definately visible flickering
« Reply #25 on: 10 November 2008, 16:31:24 »
Agreed. LEDs would need some control especially if they're driven hard.
There's no sensible reason for the flickering, but I have observed the same issue. I guess it could be a fault condition where the current (for example) exceeds some protection threshold and the device shuts down only to restart a few tens of milliseconds later. :-/
Maybe a single LED failure in a larger array would cause something like this?
« Reply #26 on: 10 November 2008, 17:30:13 »
I have used LED sidelights which flicker like hell just before failure
LJay
  • North Wales
  • The Acrobatics Queen!
    • 3.2 - MV6 Big Blue!
« Reply #27 on: 10 November 2008, 17:39:05 »
I suffer from migraine and have been known to pull over to avoid having to look at flickering lights.
Didn't think much of it though, just assumed they were faulty.
Been there, fallen over it!
