Author Topic: Sampler fan  (Read 732 times)
Dazzler
  • Haverhill, Suffolk
Sampler fan
« on: 21 November 2008, 10:31:08 »
Is there a test you can do to see if this is working???
Kevin kindly done a Tech2 on the climate system but it does not say whether the fan is working or not. However, it did show a cabin temp of 42 degree C :o
Re: Sampler fan
« Reply #1 on: 21 November 2008, 10:34:10 »
you can see if it will hold a bit of tissue to the 'vent'
not very technical, but proves if it is pulling a little in.
I stick the hoover over mine periodically, try and remove some dust build up.
« Last Edit: 21 November 2008, 10:35:00 by jimbob »
Re: Sampler fan
« Reply #2 on: 21 November 2008, 12:38:08 »
you can normally hear it on older ones.
failing than, you can see it when you've taken the console apart.
Page created in 0.009 seconds with 21 queries.
