Author Topic: fascinating hard drive stats  (Read 988 times)
jjleonard
  • stevenage
« on: 25 November 2008, 19:12:58 »
for all you IT hardware types out there:
http://www.tomshardware.com/picturestory/476-6-seagate-hard-drive.html
The dimensions of the head are impressive. With a width of less than a hundred nanometers and a thickness of about ten, it flies above the platter at a speed of up to 15,000 RPM, at a height that’s the equivalent of 40 atoms. If you start multiplying these infinitesimally small numbers, you begin to get an idea of their significance.
Consider this little comparison: if the read/write head were a Boeing 747, and the hard-disk platter were the surface of the Earth:
    * The head would fly at Mach 800
    * At less than one centimeter from the ground
    * And count every blade of grass
    * Making fewer than 10 unrecoverable counting errors in an area equivalent to all of Ireland.
 :o :o
Re: fascinating hard drive stats
« Reply #1 on: 25 November 2008, 19:14:16 »
they are no so impressive when educated with Sammy Sledgehammer ::)
Bandit127
« Reply #2 on: 25 November 2008, 19:20:44 »
 :o :o
That is a truly excellent fascinating fact. I will be boring all and sundry with that one in the smoking shelter tomorrow  ;D ;D
Good post  :y
« Reply #3 on: 25 November 2008, 19:21:30 »
Another 15K RPM ..good to hear ..prices will go down a bit :)
« Last Edit: 25 November 2008, 19:21:56 by cem_devecioglu »
jjleonard
  • stevenage
« Reply #4 on: 25 November 2008, 19:22:19 »
 :o :o
Good post  :y
May I congratulate you on your excellent use of sarcasm.  ;D ;D
It was sarcasm, wasn't it?
Bandit127
« Reply #5 on: 25 November 2008, 20:07:40 »
Nope. Not at all.
A fascinating fact should be exactly that. It was.
It should also completely fail to enrich your life one jot. Tick in the box there too.
And I will probably be telling those that listen in the smoking shelter tomorrow. (Although I will pick my audience carefully...)
Straight up - good post  :y
jjleonard
  • stevenage
« Reply #6 on: 25 November 2008, 20:20:16 »
Nope. Not at all.
Thanks! I shall endeavour to provide more fascinating facts in due course!  :y
