Author Topic: Windows XP Help  (Read 3542 times)
Techno
  • Bedfordshire
Re: Windows XP Help
« Reply #15 on: 02 December 2008, 23:28:04 »
Cheers
It's a right pain the thing is working fine got rid of some nasty little viruses but by mistake I must have ticked basevideo while unticking
safeboot in system config utility.  Now bloody stuck in cmd.exe within safemode, I'm sure all it takes is the right comd prompt and I'll be back in normal safe mode just dont know what it is  >:(
Re: Windows XP Help
« Reply #16 on: 02 December 2008, 23:52:04 »
you need to edit your boot.ini file to remove the /basevideo bit ...
If you can't edit it from the computer you have a problem with try copying a boot.ini from another XP machine direct to the faulty one ..
boot.ini is a hidden file in c:\
A "standard" boot.ini looks like this ..  :
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect /NoExecute=OptIn
At command prompt type following lines, hit enter at end of each line-
attrib c:\boot.ini -s -h
edit c:\boot.ini
DOS editor should load.  Remove refs to basevideo - file contents should look similar to Entwoods above.  When its ok save it and exit editor.  You should be at the dos prompt. type
attrib c:\boot.ini +s +h
exit
Then reboot - should be ok.
Techno
  • Bedfordshire
Re: Windows XP Help
« Reply #17 on: 03 December 2008, 14:26:35 »
Thanks for all the replies I've sorted it now it was simple just cd enter and start space nsconfig enter bingo all sorted  :y
Re: Windows XP Help
« Reply #18 on: 03 December 2008, 14:46:56 »
did you get that from my post in the other section before it was deleted?
Re: Windows XP Help
« Reply #19 on: 03 December 2008, 14:49:00 »
attrib and edit commands in dbug's post could sort also..
Techno
  • Bedfordshire
Re: Windows XP Help
« Reply #20 on: 03 December 2008, 15:02:32 »
No mate I just kept at it and it came togerther I've done this sort of thing before but I couldn't for the life of me remember last night.
Re: Windows XP Help
« Reply #21 on: 03 December 2008, 15:39:44 »
Ahh well, pity the threads werent merged :(
