Author Topic: Re: Reasonably priced Parts?  (Read 4307 times)
« Reply #15 on: 31 October 2008, 15:57:32 »
No local branch near me :(
VX1
  • Reading, Berkshire
« Reply #16 on: 31 October 2008, 16:10:26 »
Your nearest branch would be either Witney, Oxford or Swindon, Wiltshire. But keep a look out as there could be a branch opening near you!!!
Paul  :y
Vx Trade club card holder
Halfords trade card holder
Albatross
  • Bedford
  • An LSD & an S2000!
« Reply #17 on: 31 October 2008, 19:14:13 »
Voted "YES"
I think its worth looking into.
Personally, there are some parts I'll always use genuine, and some parts I'll use pattern.
Some eg prices would be good :y
Agreed  :y
I "third" that!
Nor me :-[
mike213735
« Reply #18 on: 01 November 2008, 22:23:28 »
Paul,
My forum name is mike213735....can't beleive you forgot mine but remembered Marti's and Rob's, I'm hurt!
Yes, my cambelt kit and waterpump are still going great, covered about 3k now and no problems. I was supplied with a Gates Powergrip kit by VX1.
Let me know how this goes. Don't forget to mention that we have used your premises for our mini fix it meets in the Reading meet section.
Oh, must go and vote.
Thanks
Mike (mike213735, in case you forget Paul)
« Reply #19 on: 01 November 2008, 22:43:48 »
Yeah would use parts as long as they were good quality.
VX1
« Reply #20 on: 01 December 2008, 16:56:01 »
Right just to let you all know that I have spoken to the call centre manager and he has put something in place. If you require parts from Motaquip please contact me first, through pm, and I will give you the password or you can phone me on 07900447752 and I will give it to you that way as well. You can use any branch that is close to you............
Witney, Oxford
Bristol
Melksham
Swindon
Newbury
Reading.
The person that you speak to in the Branch might need to speak to the call centre Manager as he know's about it, Plus you will need to say to them Omega Owners Forum as well.
Paul  :y
« Reply #21 on: 01 December 2008, 19:40:17 »
Fantastic... Thanks for your work on this. Unfortunately I wont be able to benefit as the nearest branch is way too far away but good for those who can :y :y :y
The Barge Captain
« Reply #22 on: 01 December 2008, 23:18:18 »
Looks good Vx1. :y
I will agree with (the boy?) that some things really need to be Vx e.g. Cam cover gaskets and manifold gaskets, but otherwise brake parts (slightly controversial I know) steering components etc. are all generally good from motor factors.  Car manufacturers do not make every single part of a car, 80% of each car is sub-contracted in, and even if a part only lasts half the time, but is half the cost then consider it a spread payment plan  ::)
VX1
« Reply #23 on: 02 December 2008, 19:06:30 »
I just bought some HT leads for the car cost me £25 all in. Now these leads are made by Delco Remy so the price isn't to bad at all so expect to pay near that price for something like that. They have told me that the prices are going tobe good for forum members, so if anyone is to far away then I am sure someone on here would get them for you and post them onto you.
Paul :y
webby23
  • Nottingham
  • MV6
« Reply #24 on: 02 December 2008, 20:23:39 »
In theory this is a great idea and should be praised.
However in practice there are too few branches to be of use to most of us and they are in too small an area.
If it were a nationwide branch network that would be fantastic.
Well done for sorting it though mate and I am sure those local to your branches will be taking you up on this.
Brad Woolley
  • Johannesburg South Africa
« Reply #25 on: 03 December 2008, 08:13:09 »
Hi,
  Any more news on the prices, I've just found out that the cambelt tensioner is not available here in South Africa, so I'm very interested in purchasing some items, in particular
2001 Omega 2.6V6
OOF CamBelt DVD
Cam Belt Kit (inc tensioner)
Water Pump
I really need a supplier who can organise all the parts and send them to our shippers at Heathrow, they will then ship them over to SA, I have a UK bank account so can pay by bank transfer, or if preffered credit card.
Anyone any suggestions ?
Brad
Anyone suggest anything else whilst I'm doing the cambelt
VX1
« Reply #26 on: 04 December 2008, 11:02:41 »
Ok some of you would like to have some prices to compare with dealer prices so here are some of the mainley used parts......
http://www.elcome.co.uk/motaquip/partPictures.asp?ID=0.7055475
Pads 2.0ltr lucas £25.48 inc should get them cheaper
Pads 2.0ltr ATE £25.48 inc should get them cheaper. These are the same for the 2.5,2.5td,3.0
Rear Pads £16.61 inc should get them cheaper
Rear Discs £81.49 inc the pair should get them cheaper all models
Front Discs £78.98 inc the pair should get them cheaper all models from V1000001
Front Discs £91.01 inc the pair should get them cheaper all models to V1999999
Oil filter £1.73 inc should get cheaper all petrol models
Air filter £9.12 inc should get cheaper all petrol models
Fuel filter £8.88 inc should get cheaper all petrol models
Pollen Filter £6.72 inc should get cheaper all models
Oil filter £7.46 inc should get cheaper TD models Ally Housing
Oil filter £7.46 inc should get cheaper TD models Plastic Housing
Drive belt (with A/C) £5.55 inc 4x770 TD models
Drive Belt (with A/C) £5.72 inc 4x800 TD models
Tie Rod End - Otr L   04/94->09/99    £27.57 inc should get cheaper
Tie Rod End - Otr R   04/94->09/99   £27.57 inc
Tie Rod End - Inr R   04/94->09/99    £20.50 inc
Tie Rod End - Inr L   04/94->09/99     £20.50 inc
Centre Rod Assy C   04/94->09/99 Exc:Lowered Suspension  £96.65 inc
Front Suspension
Susp Arm - Lwr L   04/94->09/99      £44.29 inc
Susp Arm - Lwr R   04/94->09/99      £44.29 inc
Ball Joint - Lwr L&R   04/94->09/99   £11.56 inc  each
Susp Arm Bush - Lwr Ft L&R   04/94->09/99 Front    £14.50 inc each
Susp Arm Bush - Lwr Rr L&R   04/94->09/99 Rear     £8.84 INC each
Stabiliser Link L&R   04/94->09/99       £12.19 each inc
Timing belt kit £92.07 inc (Gates Kit) should get cheaper 3.0ltr and 2.5 petrol engines
Timing belt kit £57.99 inc should get cheaper 2.0ltr petrol models
Spark Plugs £2.56 each inc All petrol models.
This should keep you all going for now at least you have something to compare with
Paul  :y
