Author Topic: Aaaargh  (Read 2733 times)
Leomas
  • Boyne Valley (on loan)
  • Ooops what did I break this time?
Aaaargh
« on: 10 December 2008, 22:02:27 »
IT'S NOT FAIR......booked the miggie in to have the thrust washer done and went out to clear all the junk out and I can't get in!!!!
Remote won't work so I presumed the battery was flat but the key won't open the door either. The key turns but the button doesn't move.
Help!
Recently 'learned up' and being more careful now, honestly.
Ummm except for where I fix one thing and break something else
Re: Aaaargh
« Reply #1 on: 10 December 2008, 22:11:21 »
Flat car battery :question don't worry, Migs are worryingly easy to get into with a piece of thin, bendable wire, pref thinner that metal coathanger. :y
Leomas
Re: Aaaargh
« Reply #2 on: 10 December 2008, 22:17:30 »
Sounds like it won't be at the garage tomorrow then......botheration
Re: Aaaargh
« Reply #3 on: 10 December 2008, 22:19:17 »
All the experts say if you turn the key clockwise with brutality,the door will unlock. :y
Ken T
  • Stockport
Re: Aaaargh
« Reply #4 on: 10 December 2008, 22:19:31 »
Can you open the boot ?. Its a bit of a crawl but....
Ken
Re: Aaaargh
« Reply #5 on: 10 December 2008, 22:20:09 »
Have you not got a piece of wire then, or a metal coathanger :question
Leomas
Re: Aaaargh
« Reply #6 on: 10 December 2008, 22:20:28 »
Suspect that may be happening any second, was only trained on the oldstyle buttons which you could do with those packing straps
« Last Edit: 10 December 2008, 22:21:27 by Leomas »
Ken T
  • Stockport
Re: Aaaargh
« Reply #7 on: 10 December 2008, 22:21:52 »
Ah sorry forgetting, its the early ones that have the lock in the boot handle. If all else fails, a brick  :'(
Ken
Leomas
Re: Aaaargh
« Reply #8 on: 10 December 2008, 22:22:19 »
forgot to mention that the key won't shift in the boot lock...probably find one of the little s***s round here has been messing about
Ken T
  • Stockport
Re: Aaaargh
« Reply #9 on: 10 December 2008, 22:25:37 »
your not in the AA are you ?. If so call them in and let them sort it out.  :y
ken
bertiecbx550
Re: Aaaargh
« Reply #10 on: 10 December 2008, 22:32:56 »
 :o :o :o I`m not parking my car round by you mike ;D ;D ;D
jjleonard
  • stevenage
Re: Aaaargh
« Reply #11 on: 10 December 2008, 22:33:33 »
this might be a dumb question (I don't know non facelift migs), but have you tried the handle?  ;D
I seem to remember Lizzie Zooms' recent post when she busted the key turning it, only to discover that the door was unlocked - just the internal button hadn't popped up....
feel free to correct me if I'm pointing out the obvious!
Leomas
Re: Aaaargh
« Reply #12 on: 10 December 2008, 22:34:01 »
Nooooooooooo not like that, wont work anyway :P
Need a long piece of wire and put a small u shape on the bottom, slide it down the outside of the door glass near the button, between the glass and the rubber strip. Slide in down and then move everyting towards the door lock, there is a bar you need to hook on, you can just about see it, hook, pull up and door will unlock.... :y :y :y :y
Woohoooooo....the old brute force wins again. Battery out and on charge, just means I get up at 5:30 instead of 5:45 so I can put it back in. Only for a miggie would I do this....
Ken T
  • Stockport
Re: Aaaargh
« Reply #13 on: 10 December 2008, 22:40:03 »
Well done  :y :y :y
Shouldn't we hide Mike's post giving instructions about how easy it is to break into our Pride and Joy's ?. Although I suspect the scroates will know this by now  :'(
Ken
Leomas
Re: Aaaargh
« Reply #14 on: 10 December 2008, 22:54:27 »
To be fair I used the 'turn the key HARD' version which does at least need the right key
 ;D ;D
