Thanks Marks_DTM
Started by TheBoy, 07 January 2007, 17:14:59
Change a front wheel bearing for me today, old one had 'a bit of play' in it.  Also tightened the play in the steering box.
So a public 'Thanks' to you Mark :y
No rumbles from the front, so a result there :), and also the steering wheel felt more connected to the car, so I'm a happy boy :D
I don't think its quite sorted the strange handling - that bit along A46 after straight bit, there is a sweeping right a mile or so before roundabout, went round there to test it at xxxMPH and it started to step out, almost as if tyre was a little flat.  Would that be due to that other suspension problem you found?  Also, still a tendency to wander sat on the M1 at 85mph...
Super Job ;D
Mark - do you by any chance work for Vauxhall for a living?  :P
Taxi_Driver
Quote Also, still a tendency to wander sat on the M1 at 85mph...
Another good job done by Mark  :y
Its been a bit windy today TB....any chance of that blowing the omega about a bit.....ive been up and down the m4 twice today....the wind pushed me onto the cats eyes a couple of times  :-/
Possibly, but the right sweeper on the A46 was most definately not wind (well not that kind anyway!).  There is a problem with the rear suspension which is likely cause...
Good to hear your MV6 is running even better  :y
Just ran mine up to Birmingham Airport @ 75mph its running very nicely on that new oil  :y
Omegatoy
Woudnt mind betting the weird handling is down to rear subframe mountings(donuts) being sloppy!!!
Omegatoy
Chopsdad
QuoteWoudnt mind betting the weird handling is down to rear subframe mountings(donuts) being sloppy!!!
Omegatoy
Just looked at you link Graham - holy shit - that's a lot of engine. 3.6?
Taxi_Driver
QuoteGood to hear your MV6 is running even better  :y
Only 75mph Tunnie?? :-? If you remove AA's mod it will go a tad faster than that  ;)
Omegatoy
Possibly. More likely to be the broken spring though....  ::)
If he goes about 75 (can a 2.2 go faster?), his mum blames me for his faster driving  ::)
Auto Addict
TheBoy got 80 out of mine (private road) ;)
I like red cars
Auto Addict
Omegatoy
Sounds expensive and difficult......
I like red cars
Ah, but yours has a proper gearbox AA, and no silly third pedal....
Auto Addict
Silly me, I forgot 8-)
I like red cars
The way that got to 80, I suspect it goes at 80+ quite frequently ;)
(Must be when Mrs AA drives it ;))
