Author Topic: fitted replacement engine today  (Read 1225 times)
shanjon
« on: 12 January 2009, 20:31:42 »
As some of you may be aware my brother in law killed his engine and it fell on me to do repairs,
well i fitted the donor engine today  which came from a guy on feebay ,,, please bear in mind i had not heard the engine run and apparently it had been sat in their yard for approx two months,
i connected the battery turned the key and it fired and run first turn and is a sweet little engine (result) even more of a result is there was no eml and the temp gauge now works :y
Re: fitted replacement engine today
« Reply #1 on: 12 January 2009, 20:34:10 »
And a job well done then...
hotel21
  • The Kingdom of Fife
« Reply #2 on: 12 January 2009, 20:35:26 »
Sounds like time well spent....   :y
« Reply #3 on: 12 January 2009, 20:35:27 »
Did you (or do you plan to) do cambelt kit, oil change, and plug change? Most important things you can do, alongside breather clean :)
STMO123
« Reply #4 on: 12 January 2009, 20:36:27 »
Good job.  :y
shanjon
« Reply #5 on: 12 January 2009, 20:38:15 »
all done , apparently it had only done 85,000 miles but i told the brother in law i needed the parts as we had no history
shanjon
« Reply #6 on: 12 January 2009, 20:39:18 »
i did make a slight little boo boo which caused me a little more work though :-[
Welung666
« Reply #7 on: 12 January 2009, 20:39:47 »
which was?
shanjon
« Reply #8 on: 12 January 2009, 20:43:59 »
which was?
in my haste i thought i would turn the engine over to check everything  was connected ok ( not expecting it to start straight away) i forgot to connect the two pipes to the rad that  come from the auto box that carries the transmission fluid  to the rad and hey presto auto transmission fluid everywhere :-[
Welung666
« Reply #9 on: 12 January 2009, 20:46:22 »
which was?
 ;D ;D ;D At least it was ATF and not hypoid! You'd be smelling like cat pee for weeks if it was :y
shanjon
« Reply #10 on: 12 January 2009, 20:53:28 »
which was?
if it smells anything like the oil used in the self levelling shocks i know what you mean, :)
