Author Topic: Quick Headlight Question adjusters  (Read 6436 times)
Re: Quick Headlight Question adjusters
« Reply #30 on: 06 January 2009, 14:41:05 »
Right. He is looking into it but at first glance looks like no problem. Two options are likely to be available:
1) Get his machinist to do them (can get them pretty quickly)
2) Use it as a project to train the apprentice (less quick, cheaper)
I'm assuming metre long lengths (for example) milled to the correct cross section is all we'll require from him.
I've asked for ballpark prices for each option.
« Reply #31 on: 06 January 2009, 16:58:32 »
Quick question.
What headlights, car models, years will these adjusters work on.
Normal or HID
Pre/mini/facelift.
Year range etc
TIA.   :y  Plus saves a lot of questions later.
« Reply #32 on: 06 January 2009, 17:46:25 »
Quick question.
Normal or HID
Pre/mini/facelift.
Year range etc
Normal and HID projecto based headlights on facelift and pre-facelift!
Kevin, 1m lengths would be ideal!
Martin_1962
« Reply #33 on: 06 January 2009, 19:14:53 »
I might have a pair too!
« Reply #34 on: 10 January 2009, 12:38:40 »
Is this a happening or do I bin the remnants of the HIDs I have in the shed.
« Reply #35 on: 10 January 2009, 13:14:42 »
Kevin has got a quote for milling.....I am raising the cash to get back to him.
We then need to look at timescales etc but, would probabaly be about 15-20 quid a pair delivered
« Reply #36 on: 10 January 2009, 13:31:55 »
I'll have a set :)
Jim
  • Glasgow
    • Irmscher 3.2 V6 Elite
    • My Vauxhall Omega's
« Reply #37 on: 10 January 2009, 13:43:03 »
Quick question.
Normal or HID
Pre/mini/facelift.
Year range etc
Also Xenon Facelift and Pre-Facelift have this type of adjuster inside them :y
Jim
  • Glasgow
« Reply #38 on: 10 January 2009, 13:47:39 »
Does that include the ball on the end fitted etc
« Reply #39 on: 10 January 2009, 13:49:08 »
Yes....thats the whole item.
Kevin has a quote for the milled bar stock.
I would then drill and tap this and fit the ball to the end
Still waiting on info regarding the availability of the balls
unlucky alf
  • worksop, notts
« Reply #40 on: 10 January 2009, 15:12:06 »
do you know the ball size in old money [imp]DTM?, its just that AMF bowling machines have 22 of these things per machine & i still have contacts so can get them with no problem, the only thing is the threaded bit is 1/4 unc but not a worry as they wont need to be removed anyway, if i can find my AMF parts list i`ll let you know the ball size in imperial.
« Reply #41 on: 10 January 2009, 16:27:13 »
8mm.
I have a company who supplies them for bonnet strutts coming back to me this week.
« Reply #42 on: 10 January 2009, 19:22:21 »
Ill have 2 pairs!
ie 4!
does the quote include fitting  ;)
Martin_1962
« Reply #43 on: 10 January 2009, 21:18:33 »
1 pair as I think my left one is going
Jim
  • Glasgow
« Reply #44 on: 10 January 2009, 21:28:03 »
I'II have a set,
Are you just checking out intrest at the mo, and them pending are you going ahead with getting them made up
« Last Edit: 10 January 2009, 21:29:28 by jim »
Pages: 1 2 [3] 4  All   Go Up
